TR4/4A BRG Paint code [again]
shoopal
Hi all
Got my restoration project ready for paint. The shop wants to use PPG Envirobase. I want the dark BRG color which has the factory code "75". Can any one give me the PPG equivalent. I think that this was the 1975 TR6 color
Thanks in advance
Al
TR3driver
Great Pumpkin - R.I.P
Joe Curry posted a long time ago that Triumph code 75 was PPG mix 42487 That number is probably obsolete (and was certainly not Envirobase), but maybe your shop can cross-reference it.
S
shoopal
Hey Randall
You really do have all the answers. Unfortunately PPG does not have a cross reference for 42487 in the Envirobase (water based) line.
We are going to try something close which is Jaguar BRG and add a little blue.
We are making up some test samples and trying it out on spare sheet metal.
If any one is interested, I'll post the formula
Breaking News: PPG does cross reference 42487 in their Deltron DVC (2 stage) and Concept (single stage) lines
They are emailing me the formulas which I will faithfully pass on.
Al Shoop
S
shoopal
Screen dumps of codes
S
shoopal
No NY restrictions. It's just that the body shop is set up to mix up Envirobase but they can buy DBC from a local supplier. 45102 is the number that I have been looking up but no cross-ref for envirobase. I'm going to order up a small quantity of the DBC to see what kind of match it is.
CJD
Post a pic if you can...I think I would like that color for mine! Unfortunately the PPG paints are highway robbery. The last pint of DBC I bought was $78/$124 per qt.
S
shoopal
Just got off the phone from PPG mixer. Ordered 1 Oz each of the two formulas. $10. each
Picking up Sat. Will test spray and take a picture. Post it next week
S
shoopal
OK. Tried the samples. DCC on top, DBC on bottom
The DCC (single stage ) was the closest to the original "75". The DBC base coat/ clear coat was not quite as dark and closer to the "25" code . Also attached is the formula from the Allard car which is a pretty snazzy car but somewhere in between the other two.
I have decided to go with the DCC formula. The estimate cost is $500 / gallon which is probably way more than I need even including the interior.
Good luck every one.
CJD
The DBC has an olive tone to it. Of the 2, I agree, the DCC looks the most accurate.
Usually the 2 types should look identical, with the clear coat giving the DBC a better gloss...and much more durable shine. I would imagine they have trouble mixing exactly with such small samples. I used to use paint scales to balance engine parts as they are the most precise scales I have ever found. The smaller the paint sample they mix, the more difference a small mix error makes.
The DCC is most popular in trunks and engine bays, where it is difficult to uniformly spray the clear back over the base.
For planning, my TR3, painting the entire tub and all the back sides of the wings, bonnet, apron, etc., it took 1-1/2 gallon of the DBC. Every time I pay $2k just for the paint on a restoration, I think of my Old Man, who used to put $100 MAACO paint jobs on all his cars. Of course, his paint looked good for a month. Modern Urethanes last decades.
S
shoopal
Good info. By the way is your estimate of 1 1/2 gallons for your TR3 including the reducer and hardener? They recommended 3 qts paint, 1 1/2 qt reducer and 1 qt hardener totaling 5 1/2 qts, 1/2 qt less than your estimate. For reference, that entire order comes to $630 including tax
CJD
No, the 1-1/2 gallon was just the DBC! But, that was painting every square inch of the body, inside and out, and the DBC does not get hardener. For most cars I have done, a gallon is about right, with just enough left over for later touch-ups. The TR3 has a lot of removable panels that ran up my total the extra half gallon.
Since you are using the DCC...the hardener does increase the volume to make an even gallon, which should be pretty close. You can reduce what you need a bit by using a primer that compliments your color...in your case using a black primer instead of light grey. Also, most paint shops charge almost the same to mix a gallon of color as they do for 3 quarts. It may be worth asking them the price for a gallon of the color. You wouldn't have to purchase the reducer and hardener unless you needed it later.
S TR4/4A TR4A BRG #75 paint code Ditzler 42487 Triumph 3
wangdango Dark BRG paint code Austin Healey 11
wangdango Dark BRG paint? Austin Healey 6
W BRG paint Jaguar 2
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
PC Brg mgb Spotted 0
D Brg mga w/w Spotted 0
D BRG Caterham Spotted 5
H BRG on my 3000? Austin Healey 25
Mickey Richaud BRG Rubber Bumper B Spotted 0
Tabcon BRG or Black, or both? Restoration & Tools 2
jvandyke Sighting: BRG BE in Grand Rapids, Michigan Spridgets 0
I 60's Jag BRG ?? Jaguar 10
germanmichel Please give me your opinion. pacific or brg ? Austin Healey 21
RickB MGB Nice BRG MGB at Fort Clatsop today, was it yours? MG 4
A BRG-dark. Triumph 28
Alan_Myers GT6 BRG GT6 Mk III in San Jose? Triumph 0
vping PPG for BRG MG 13
Bruce Bowker MGB MGB BRG witrh red interior?? MG 28
R TR2/3/3A BRG TR3 Triumph 1
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
