gbtr6
I got a breather tank before my engine rebuild as before the rebuild, it was pushing oil out the top. Reason was number one piston was just pumping air and pushing it out. Anyway, I installed the tank and connected to the vent on the valve cover. It showed it had fluid in it so I emptied it. It seemed like mostly water, with brown globs of some oil. Is the water to be expected? It didn't have much oil in it so I know that's OK. I assume the water is because of the temps in the engine and it creates water vapor.
Is this an issue?
Perry
Is this an issue?
Perry
