Breakdown causes?
T
Tinster
This will sound like a silly topic but it is serious
for me since I have no other TR6 to compare.
My car breaks down down primarily due to to failed coils,
failed fuel pumps, ignitions parts, failed condensers.
I carry lots of spare ignition parts and fuel pumps.
I am wondering what are other weak coponents contribute
to breakdowns? I will carry 2 or 3 of these in my trunk!
Only once did I have a wheel fall off at speed..
thnks,
dale
Geo Hahn
I have AAA Premier 200 mile towing so the spares I take on board fall into 2 categories:
For trips w/i the tow range I only take things I would repair/replace roadside, such as ignition components (all of them), electric fuel pump, hoses (all of them), 'fan' belt, ZS diaphram, assorted wire, etc. I assume other items such as a failed water pump would mean a tow home. I can drive 200 miles w/o a generator so that too is omitted.
For trips beyond 200 miles I take the water pump + pulley, a mech fuel pump, generator, control box, U-joints, etc. on the assumption that I could swap these components in a motel parking lot (hopefully at a Triumph event with lots of willing & competent help).
That said, my only major breakdown was not covered by the above -- a failed rear wheel bearing seal that caused the brake shoes to fall apart.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Well, you DO have a spare tire in the trunk, don't you?[/QUOTE]
Actually two. Wendy can't sit in the passenger seat anymore.
trrdster2000
Dale, over the years I have had all you speak of but of all, a wiring problem can give be the hardest to have something to repair it with. If yout switch goes bad or a wire burns up, I always keep a 3 foot 12 gauge wire with alligator clips on the end to bridge the gap, say from positive batt end to positive side of the coil, if your switch goes bad, you can still push the car off. You could put a fuse in line if it makes you feel better.
Wayne
Geo Hahn
trrdster2000 said:
...I always keep a 3 foot 12 gauge wire with alligator clips on the end to bridge the gap...
I finally made a pair of leads (red & black w/alligator clips) long enough to reach from any where on the car to anywhere on the car.
Brosky
Wayne,
Don't let dale fool you with his dismissal of his abilities. He single handedly installed the complete Dan Masters wiring harness and added many new grounds. His electrical system is probably better than 95% of our cars.
And I know that he has 10, 12 and 14 gauge wire and connectors to match somewhere in that trunk of trunks......
poolboy
It would be interesting to know if those strange looking spark plugs that you use (according to your pictures) are placing too high of a voltage demand on the other ignition components.
These old timey engines really don't require anything more than a good copper electrode spark plug.
B wire wheels tire breakdown Austin Healey 23
Tr3aguy MGB MGB glove box lock breakdown or photos MG 4
RedTR3 TR2/3/3A Breakdown July 4 Triumph 11
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
T Breakdown around the next bend. Triumph 13
T Enduro breakdown kit completed Triumph 35
Pythias ABFM------- BreakDown! Spridgets 9
T 6.8 miles w/out breakdown!! Triumph 47
jlaird Progress-engine breakdown Spridgets 6
SCguy TR6 Diagnose my TR6 breakdown The Winner is... UPDATE Triumph 18
8 FIRST BREAKDOWN Triumph 10
T Breakdown prevention? Triumph 42
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
J MGB What causes this puzzle? MG 4
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
B Clutch causes engine to stall? Spridgets 5
K Common causes of Differential Seal leak? Triumph 13
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
boeingpilot What causes "run on" Triumph 9
58Custom What causes popping out of first? Spridgets 0
T What causes an engine to backfire? Triumph 15
Luke_Healey Causes of dieseling on shutdown? Spridgets 21
wkilleffer What causes heat soak, and is it a bad thing? MG 16
A Heat in engine bay causes idle to drop? MG 37
K Coolant in oil likely causes? Triumph 6
Mark_Gibson TR6 TR-6 Positive Rear Wheel Camber Causes Triumph 8
J uneven camber-- causes? Triumph 9
J Lack of Diesel Engine in Europe causes slowdown in X type sales and production Jaguar 0
