Brass Freeze Plugs
Rob Glasgow
Does anyone have a source for 1-5/16 brass freeze plugs? I can get them in steel from Moss but I would like to use brass if possible. The 1-5/8 size is available, but I can't find the smaller ones. Any ideas?
Healeysince59
Any real parts house that has Dorman items will have them or can order them. My local source makes me buy a whole box (6 or 8) if it's not a size that they normally stock.
Marv J
Rob Glasgow
Rob Glasgow
Marv J, I just checked the Dorman web site and I could only find steel plugs in that size. Have you purchased 1-5/16 brass plugs from them? If so do you have a contact other than the Dorman site?
Hangtown Healey
I went through this a few weeks ago and the FreezePlugFactory is the only source. There is a minimum buy, but the price is still reasonable. I think about $35.
Rob Glasgow
Rob Glasgow
Hangtown Healey, Did you wind up buying some and do you have 5 of each size (1-5/16 and 1-5/8) left over that you would like to sell? I would be interested. Let me know.
Hangtown Healey
I have 4 big ones and 5 little ones left over. Lets see after I fire up the engine this week or next. The big ones are same as Chevy V8 so Dorman might have those in brass.
F Brass freeze plugs BJ8 Austin Healey 4
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
A For Sale Mystery brass intake manifold Other British Classifieds 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
S TR2/3/3A lower small brass bushing Triumph 13
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M Brass F type radiator shell build Restoration & Tools 11
M TR2/3/3A O/D brass cap leaking Triumph 5
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
Jim_Gruber Removing brass bushings from spindle Spridgets 9
5 brass steering box bushing Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
DNK Brass Tags Triumph 6
P Engine brass Triumph 1
Nelson Brass manifold nuts? Spridgets 5
angelfj1 Brass Body Tags Triumph 2
rlich8 Brass Carb Dampers? Triumph 6
58Custom Question re: brass plugs in deck of cylinder head. Spridgets 7
C 45 shipped in the USA brass over flow, Polished Spridgets 5
NutmegCT paint a brass radiator? Restoration & Tools 7
tinman58 TR2/3/3A Brass tags TR3 Triumph 8
I TR6 TR6 frozen brass lower trunion Triumph 3
S TR2/3/3A brass bushing tr3 Triumph 6
19_again brass or steel synchro rings MG 7
gsalt57tr3 Brass body tags Triumph 16
I zenith stromberg float brass plug removal help Triumph 14
rlandrum Finishing the Brass Trunions Triumph 26
L Shinny Brass top radiator Triumph 4
6 Question re: Welch Brass Radiator Austin Healey 5
Luke_Healey Throttle cable brass piece stuck in cable stop. Spridgets 7
timbn2 Metal AND Brass door hinges...huh????? Austin Healey 5
J Brass in steering box - GL5 danger? Triumph 7
H Austin Healey 100 S Original brass plate on Ebay Austin Healey 9
SCguy best cleaner for brass connectors? Triumph 7
PeterK TR2/3/3A TR3A brass body plate Triumph 4
3 BMW corporate brass comes to visit. Triumph 10
tahoe healey brass dampers Austin Healey 8
tahoe healey Brass nuts [ Manifold Hardware ] Austin Healey 6
B Brass brake cylinder sleeves Jaguar 6
