Brake Question part three
T
Tinster
So OK!!
I've restored my rear suspension and adjusted my new rear brakes. Car stops very well.
I noticed something today, so for my TR6 leaning curve,
what did I notice?
I have driven a clutched vehicle for 45 years now.
I always start my vehicles in neutral gear, brake pedal
pushed down, hand brake full on. Then I turn the crank.
Today I noticed that when I have the the new brakes of my
TR6 pushed down, as soon as the engine starts, the break pedal
falls about an inch toward the floor. Is this just the vacuum
assist kicking in? Or something else.
My brakes are all four new with less than 2000 miles driven.
thanks,
dale
Mickey Richaud
Yep - vacuum's doin' its thing.
Think of it this way: If the engine's not running, there's no assist. Then all of a sudden...
TR3driver
Great Pumpkin - R.I.P
That is actually a good test for whether the booster is working. You apply the brakes several times with the engine off (to bleed off any residual vacuum in the booster), then start the engine with your foot on the brake. If you can feel the drop, the booster is doing it's job.
But a healthy booster will hold vacuum for a long time, so it's common to not notice this at startup, unless the brakes have been used with the engine off.
T
Tinster
Wow!!
I can hardly withstand my joy!!
Something on my car is functioning properly
and will NOT cost me $$thousands to replace??
I am stunned.
dale
Brosky
Stop looking for problems and enjoy the car. Get out of the garage and go drive the car.
R
RonMacPherson
Dale, learning curve. Thought we went over this booster diagnosis procedure a loooooong time ago...
You mighta been on a cruise..
Now get the handbrake fixed where it locks...
T
Tinster
<span style="color: #990000">But it's winter, Paul !! Triumphs
live in garages during winter months.
Heck, including the evening parade last night,
I think I drove Amos 4 to 5 hours yesterday.
Other than almost killing a mom and her two kids,
I had a great time.
d</span>
kodanja
Dale are you on a killing spree again?
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Other than almost killing a mom and her two kids,
I had a great time.[/QUOTE]
Dale,
You're great guy and we're all trying to help, but these type of posts are getting over the top.
K TR2/3/3A Brand new brake caliper question... Triumph 8
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A Brake system question - Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
K TR2/3/3A An odd brake question? Triumph 2
K TR2/3/3A Brake pad Question Triumph 3
Lin Brake hard line question Austin Healey 4
J TR6 TR6 Brake Question Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
K Midget Brake Pedal Question Spridgets 2
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D TR2/3/3A clutch/brake pedal question Triumph 4
K TR2/3/3A 3rd brake light question Triumph 3
D BJ8 brake master cylinder question Austin Healey 6
D brake drum question Austin Healey 5
JPSmit Brake Pads - question Restoration & Tools 10
roscoe Brake pad question Austin Healey 3
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
I TR6 Brake caliper question Triumph 7
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
B Another disc brake question Spridgets 10
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M TR6 Brake master cylinder question. Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
T TR2/3/3A another brake master cylinder question Triumph 16
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
sd80mac7204 Spitfire 1970 Brake question Triumph 3
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets question about brake master cylinder Austin Healey 12
nevets Question about brake bleeding Austin Healey 13
J MGB Question on the brake warning light for 78 MGB MG 6
C question on the front brake lines for BJ8 Austin Healey 2
D Question on brake rotors Triumph 3
bugedd Brake bleed question Spridgets 9
bugedd RX7 rear axle and brake question Spridgets 2
H brake/rotor question Austin Healey 28
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
D TR2/3/3A TR3 brake rotor question Triumph 4
Mowgli81 General Brake Question & repair manual Austin Healey 25
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
A Wedge 1980 TR7 Brake master Question Triumph 5
T Rear brake clyinder orientation question Triumph 4
J Question on rear brake mounting plates Spridgets 5
