Hello and thanks for the warm welcome. New member. I have been viewing posts regarding brakes and the master cylinder and I am seeking opinions. First, you should know my level of mechanical ability. Minimal. Good typist, though. As mentioned in my New Member post, Ignorance and Bravery are often closely linked. A new adventure has begun.
My wife's 74 Midget won't stop. It appears to be the master cylinder. No pedal at all. No visible leaks anywhere. With the cap off the MC, pumping the brake barely disturbs the fluid in the MC. Any other tests needed to confirm?
Assuming it is the master cylinder, is this something a novice should try rebuilding or should I have it rebuilt by a pro or should I replace. Long term goal for the car is a complete restoration though it is driveable now. Restoration won't happen for a year or two at the earliest.
Thanks for your help.
