Brinkerhoff
Donny, on a Healey 3000 thats been sitting for 25 yrs. , do the entire brake hydraulic system if you're going to rely on the brakes to stop the car and not the front sheet metal. Kevin
Donny_L said:Kevin( Brinkerhoff) No worries mate. I need all the input that I can get. I'm looking at this break thing as a blessing now. Thank God it happened in the garage and not on the road at speed. So I've scrapped the ordering for all the front end stuff,that was way out of my leag anyway and focusimg on the breaks as first priority.
Donny_L said:Well right now my OD isn't working.
I know that it does function because while doing some test runs with the trans tunnel off I could I'd reach over and apply just a little pressure with my finger tip on that small lever on the passenger side of the trans and it would kick in.
Do you think a new switch & silanoid will fix her up?
Sounds like a "Weak" solenoid! PatrickDonny_L said:Well right now my OD isn't working. I know that it does function because while doing some test runs with the trans tunnel off I could make it work. once I got up to speed,I'd flip the switch and nothing would happen. Then I'd reach over and apply just a little pressure with my finger tip on that small lever on the passenger side of the trans and it would kick in. Do you think a new switch & silanoid will fix her up?
----------------- :lol:-------Keokewhy said:I fixed mine with the same technique used with the starting motor when it won't turn, a few whacks with the lead knock-off hammer. If you have a willing assistant, have them pump the brake while you whack away on the switch with the hammer.
Jay
'65 3000
elrey said:heck, it just might work. but I gotta say I haven't laughed so hard in a long time! May not be the best Idea.
