TR2/3/3A Brake lights at night?
HighAltitudeTR3
Hello I was driving home last night and noticed I didn’t have brake lights when my lights were on. The brake lights work without the lights on (like regular day time driving) so I know the pressure switch is good. The bulbs are all pretty new, so I’m not concerned it’s the bulbs.... any thoughts out there?
HighAltitudeTR3
HighAltitudeTR3
I do. I think it’s grounded at the front (in the harness) and at the light itself.
TR3driver
Great Pumpkin - R.I.P
Are your taillights the same brightness as the brake lights? If so, the rear fixtures are wired wrong, or the bulbs are in backwards.
Otherwise, my guess is still bad grounds, possibly even between the bulbs and sockets.
Take the lenses off, and check the voltages right on the bulbs. One of the very few advantages of that fixture is that the bulbs are exposed enough to do that.
If you find that both filaments are getting power, but you can't see the difference between both of them and just the tail filament; the wrong filament is coming on for the tail lights. They are intentionally supposed to be much dimmer, so the difference is obvious. But tail plus brake looks the same as just brake.
A 100-6 Brake Lights Austin Healey 2
D Brake Lights Austin Healey 7
JFS Wedge Brake and Tail lights Triumph 3
P LED Brake Lights Austin Healey 2
O Brake Lights Inoperative Austin Healey 11
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
K TR2/3/3A Blinking the Brake lights? Triumph 5
R Brake Lights Austin Healey 23
R No brake lights! Spridgets 2
Wana Brake lights on all the time Austin Healey 41
Martinld123 Brake Lights But No Turn Signals Austin Healey 9
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G MGB Turn signal, reverse and brake lights MG 9
S Look Ma! No Brake [lights] Spridgets 13
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
KVH TR4/4A No Brake Lights Triumph 11
5 No brake lights Austin Healey 4
S No Brake Lights Austin Healey 5
drooartz Brake lights always on Spridgets 21
B oh curmbs! turn signals and brake lights were... MG 14
R Brake lights won't shut off Triumph 8
V TR2/3/3A TR-3 Brake Lights Inop Triumph 2
D Brake lights stopped working Austin Healey 40
stretchit2 Turn Signals , Brake Lights, Off Switch - Yikes Austin Healey 1
longbridgehealey No brake lights and car won't turn off?? Austin Healey 20
R Bugeye Brake Lights Spridgets 2
G MGB '71 MGB brake lights MG 18
C Everything was goin good... now no brake lights Spridgets 8
F No Brake Lights MG 5
Mio Brake lights - daytime only Spridgets 2
TimK Brake lights/turn signals/DB10 Relay issues Austin Healey 5
C Wedge TR 8 Turn signals and brake lights. Triumph 12
Stewart Brake lights stuck on MG 2
P TR2/3/3A TR3 Brake Lights Triumph 11
Raymond Dim tail/ Brake Lights MG 32
P extra brake lights Triumph 10
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
R Brake & Tail Lights NONE! Austin Healey 3
I TR6 TR6 brake lights Triumph 10
I TR6 brake lights TR6 Triumph 8
KLUTZ Brake lights always on MG 7
W indicators and brake lights not working Triumph 9
S Flunked Inspection- No brake lights on 79 B MG 6
G brake lights & reverse dont work.. MG 1
W Brake lights stay lit! MG 13
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
