brake caliper color
BRSLimited
Does anyone know if the brake calipers on a TR4 were painted and what color or where they just left natural to rust on their own?
DNK
Any color you like. Just use the right type of paint
Deleted member 8987
Mix up rust, dirt, blister, with a tad of asbestos, and you've got it just right.
kodanja
paint them any color you want'
I went with John Deer yellow'
even Praying Mantis's like it'
lbcs_r_fun
No. Never painted, at least not by Triumph. Regardless of whether cast iron or aluminum, they clean up real nice (plastic media) and then a clear coat!
M Dunlop Brake Caliper correct color? MG 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
B TR2/3/3A Caliper brake line Triumph 10
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
K TR2/3/3A Brake caliper hold bolts? Triumph 1
K TR2/3/3A 62 TR4 Brake caliper? Triumph 5
I TR6 Brake caliper question Triumph 7
C TR6 Leaky brake caliper Triumph 6
Jim_Stevens TR2/3/3A Brake caliper corrosion Triumph 5
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
R Correct Brake Caliper colour Austin Healey 9
T General Tech Brake caliper - piston stuck Triumph 4
HealeyRick Brake Caliper Upgrade Austin Healey 120
M_Pied_Lourd TR2/3/3A Brake Caliper Piping Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
Michael Oritt GT6 GT- 6 Brake Caliper/Mounting plate information needed Triumph 4
T TR6 Brake caliper lock after some driving Triumph 3
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
M TR2/3/3A "59" tr-3a brake caliper Triumph 3
K TR2/3/3A TR3A Brake caliper thread chaser? Triumph 2
K Is there more than one type of 16P brake caliper? Triumph 14
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
Darrell_Walker Wilwood brake caliper bleeders Triumph 12
doughairfield TR4/4A TR4 Brake Caliper Re-Assembly Triumph 9
S MGB-GT mgb gt brake caliper rebuild kit? MG 2
Phil73 Brake caliper issues Triumph 5
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
B brake caliper shims Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
I TR6 TR6 - how many brake caliper shims? Triumph 26
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
prb51 TR2/3/3A FYI TR3 Brake Caliper Seals/Pistons Triumph 0
jjbunn Wanted: 16P LH Brake Caliper Triumph 21
T TR2/3/3A TR3b brake caliper options Triumph 4
S TR6 tr6 brake caliper rebuild Triumph 3
F Brake Caliper Rebuild Problems... Triumph 12
SCguy Braided Steel Brake Lines with Toyota Caliper Triumph 19
G Brake caliper cylinders MG 9
