[ QUOTE ]
I do have a booster, but the brakes are hard to push. Car does stop, but much pressure must be applied to the pedal. The brake pedal is slightly further down than the clutch or accelerator pedals. I am going to check into aligning the pedals per instructions on one of the posts.
Charlie
[/ QUOTE ]
Given that you have a booster Charlie, then it just may be that the booster was added without changing the master cylinder over to the correct size as mentioned by BR1.--Keoke-?
