T-Series Brake bleeding MG TD
vickxxx
So I've gone thru and replaced the entire brake system on my 52 MG TD. My first attempt at bleeding was traditional, with the help of an assistant at the brake pedal, starting at the furthest point, opening valve,press down, close valve, let up, till no more bubbles. Did the same with the remaining cylinders. Checked the pedal and it was low. Did this a few times with the same results. I checked all connections and no leaks. On the next round of bleeding, I adjusted each brake so the drums were locked up, and then bled them as I did the first time. The results were the same.
On the front drums, there are 2 cylinders to adjust per side, but you can only adjust one of cylinders once the drum is locked up. I'm not sure if this would have an affect on my results.
Any ideas?
Jim B.
I have had similar issues with my 52" TD.
I had thought it had to do with changing to DOT 5 Silicon oil.
Letting it sit a while I found fluid running down a couple of wheels.
I then went through and installed NEW copper sealing washers on all the wheel cylinders, the Master cylinder, the joint over the rear axle and all the hoses.
Only then was I able to get a good peddle.
So did you change yours?
On the front, I closed down the play but did not quite lock one cylinder, rotated the wheel and did lodk up the second.
As you re-bled, did you see any bubbles in the hose?
vickxxx
vickxxx
Yes. I replaced all of the copper washers at the houses and the banjo fittings and the master. On the initial bleed I did have a leak at the rear union above the diff leak, right rear banjo fitting and right from banjo fitting. Once i snugged those down leaks stopped. I'm letting it sit for a day to see if any more leaks develop before I go thru the bleeding process again. I didn't see any bubbles in the hose and that was even before I discovered the rear union seeping. So I think i'll let things settle a bit and then go at it again. I'll definitely try adjusting one front cylinder and then locking id down with the 2nd. Thanx for the info!
vickxxx
vickxxx
So after letting the brakes sit for over a day, I went back and found some seepage at the front union. I tightened those up and proceeded to lock up the drums. Bleeding was smooth and went very well. No bubbles in sight. Clicked back all the drums. Pedal is at a good height and looks like I now have some stopping power. I'll re-adjust again after a test drive.
Sarastro
I don't know how empty your system was before bleeding, but if it's dry, or very empty, it can take a while to get all the bubbles out. The fluid releases them slowly and I suspect some stick to the insides of the wheel cylinders, too. Tapping the wheel cylinders lightly with a wrench or small hammer between bleedings can help.
When I did my TD, it was quite dry and it took a couple tries to get it bled well. On the positive side, the body was mostly off, so it was the only time I was ever able to operate both the pedal and bleeders on all the brakes by myself.
PAUL161
On new systems I pressure feed the fluids from the wheels back to the MC. Longest line first, etc. As soon as fluid is seen in the MC, I go to the next line, doing all 4 that way. Naturally the MC has to be monitored closely to keep from spilling over. I do MGBs this way also. Doesn't get rid of 100% the air, but very little is left. PJ
David_DuBois
Something else, that no one addressed - With silicone fluid, you have to press the pedal slowly to keep the fluid from cavitating and producing bubbles in the lines. If everything is good now, drive the car for awhile and then try bleeding again to get any residual bubbles out of the system. Cheers - Dave
vickxxx
vickxxx
Yes, the system was completely dry. I installed all new pipes, hoses, MC, all wheel cylinders, brake shoes. The pedal is up, but i'm still finding some "sweating" at some of the pipe joints. It's a slow process but it's getting there. thanx for the tips.
Peter Howe
I dont have a TD or even an MG but Bristols and Riley's all use similar brake system components and I have found that the best and fastest
way to effectively bleed the brakes is to use a speed bleeder which either sucks break fluid out of the bleed nipple or pressurizes the master cylinder. Either way, providing you keep the reservoir full you bleed each wheel until there are no more air bubbles and close off the bleed nipple.
For me, a perfect result every time. Air or fluid leakage at the banjo unions or any other join is clearly a separate issue and easily corrected. Hope this helps. Cheers Peter
A
akbaradeli
Hi,
Common Signs of Needing to Replace Your Brakes
If the friction material has worn down excessively, get them replaced. Squealing Noise. If you hear a squealing or screeching noise when you push your foot onto your brake pedal, this is a sign that your brake pads are almost worn out and that they need to be replaced.
Platinum
Even though the original post is nearly five years old, Peter makes a good point. I've used Gunson's Eez-i-Bleed system for years, commercially. Makes a one-man job of bleeding a brake system on most of our old lumps.
Hi,
That has little-to-nothing to do with the original poster's question about bleeding MG-TD brake systems. The OP stated he'd already replaced the entire system; lines, cylinders and shoes included.
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Govtslug TR6 Brake Bleeding Triumph 58
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
N Need brake bleeding advice Spridgets 6
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
nevets brake bleeding Austin Healey 13
R General Tech One Person Brake Bleeding with a Mityvac Triumph 12
Simmo Series 3 E Type Brake Bleeding Jaguar 2
jlaird Brake and Clutch bleeding Spridgets 7
N Need Brake Bleeding Help Spridgets 25
J TR2/3/3A Brake Bleeding problem on a TR3A Triumph 19
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
nevets Question about brake bleeding Austin Healey 13
D TR6 76 TR6 New Brake Bleeding Triumph 4
KVH Bleeding the Brake Master Cylinder Triumph 8
B Brake bleeding issues....Help please... Triumph 16
D Dual Circuit Brake Bleeding Triumph 7
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
Basil Brake Bleeding Wish me luck Jaguar 10
O Jaguar ABS Brake Bleeding Jaguar 1
Basil Bleeding an XKE Brake System Jaguar 6
WALTER Later model brake bleeding Spridgets 17
Nelson Brake bleeding Spridgets 22
glemon MGB MGB Brake Bleeding MG 14
tahoe healey brake bleeding Austin Healey 7
tahoe healey brake bleeding sequence Austin Healey 2
Monark192 Brake Bleeding Question MG 22
Michael Oritt Bleeding dual master cylinder brake system Austin Healey 6
D Brake Bleeding Triumph 2
MadRiver Brake bleeding problems Triumph 10
MadRiver Brake bleeding advice Triumph 12
A Brake bleeding [say that three times fast] MG 6
S Brake Bleeding Problem!? Triumph 6
tr6web TR6 Brake MC and bleeding TR6 Triumph 7
George Zeck Brake Bleeding ?? Spridgets 15
L Brake Bleeding MG 2
6 Brake Fluid Spridgets 1
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
