TR2/3/3A Bracing the tub for removal fom frame?
Suncoaster
Hi everyone,
Can somebody point me to a photo that would show the points at which a tub brace should be attached prior to the tub’s removal from the frame? I found a pic on the home page of Macy’s Garage that shows a brace arrangement, but I can’t tell for certain where it’s attached. The rear of the brace looks like it might be attached to the rear wheel arches – would the fronts of the brace be bolted/welded to the body mount points close to the fronts of the doors? Also, the car (center image) still has the wings, bonnet, and boot lid attached. https://www.macysgarage.com/
Several searches didn't yield much in the way of specifics. I went through John’s (CJD’s) “Beginning the TR2 Bodywork” thread, but all the photos I found of the tub showed no bracing that I could see. Here’s a link to the photos I found (pics start at post #168). https://www.britishcarforum.com/bcf...ning-the-TR2-Bodywork/page9&highlight=bracing
Again, thanks in advance to all for any info.
bobhustead
Drill and attach a plate to each of the hinge attachment points in the A post and one to the latch attachment point on the B post. Weld an angle or tube (3/16 or bigger) to the plate on the top hinge and to the plate on the latch. The bottom hinge plate gets one end of another angle or tube and the other end of that strut is welded to a plate which has been attached to the lower part of the B post. I used bolts on this. You could weld. If the whole B post is to be replaced, you will need to attach the rears of both struts to something solid that is going to stay assembled. The idea is that when you fit new floors and sills, the doors will find the A and B posts where they were before. No magic to the attachment points. rear wheel arches should be fine too.
bobhustead
While I was able to retain my A and B posts, if you need to replace yours and are going to attach your braces to something other that the B post, make "dummies" that go to the B post and put them aside to use to position the new B post. John Durant will probably come along soon with some other ideas.
CJD
Having read the book on restoring the TR's, I took a lot of time bracing my first restoration. I soon learned that it is not generally necessary. Even with no floors, the body is sturdy enough to be removed, worked on, and replaced without the bracing. That said...there are stories buried in the forum archives of owners who did not brace and placed the body on a trailer to go to the blasters, painters, etc...and the outcome was dismal! Bumping down the road on a trailer will definitely spring the body. My TR2 had almost no good metal, but it still held it's shape after removing it from the frame. The inner sill provides all the strength...so it is the key.
So, if you are keeping the body "in house", so to speak, I personally would not bother with bracing. If you plan to farm it out or transport it somewhere without the frame...then do brace.
As far as the bracing goes...just a steel bar from the A pillar back to the top of the B pillar will work. Some bolt...but, since you likely have a welder to do the restoration anyway, welding it easiest. Just tack it in place and grind off when you don't need it. You can add more bracing if you like. You can find pics, also buried here, of guys adding 45's to the doorways and even across from side to side.
M_Pied_Lourd
Hi Rick,
Here’s what I did on my 59. They work for lifting the body off the frame etc. Some guys prefer to do a more internal structure so you can fit the doors on with the bracing in place but I just remove the bracing if I need to do that.
https://youtu.be/9MFk5fQS7PA
Cheers
Tush
TRHARDTOP
Here are some photos of the tub bracing I did on my '61 TR, just some simple angle iron into the existing bolt holes.
The tub stayed aligned through body removal from frame, transportation, blasting, rotisserie, paint etc and back onto the frame.
Cheers,
Colin
S
Suncoaster
Thanks, everybody! Great info.
Since all the work will be done at the same shop, I think I'll probably go with John's method and ask the shop just to go with a steel bar or angle iron from the A pillar back to the top of the B pillar.
On the upside, TRF announced a sale today that includes their complete body mounting kit as well as other needed bits & pieces. Additionally, I noticed their cages & nuts are on sale (parts CN1/Cage & CN1/Nut - there's also a CN2/Cage that's a bit wider (longer?) for the rear wings). I spoke with Albert and he said that the nuts are the right size and won't spin in the cage. I going to go ahead and order a bunch of each. I'll report back on how they seem to fit each other when they arrive.
Thanks again to everyone for the help (And additionally to Tush and TRHARDTOP for the visual aids),
martx-5
My garage isn't very large (1-1/2" car), so I needed a way to brace and also to lift the body when necessary to work on the chassis. I could easily lift the body from the frame and roll it out in the driveway using an engine lift. The cross brace is centralized so the body balances when lifted.
mgedit
I braced the door opening by bolting angle iron at the hinge and striker plate locations.
Cheers, Mike
DavidApp
I braced the door openings by tack welding some angle in the gap. Also I constructed a frame to lift the body as I would be working alone and lifting with an engine hoist.
It all worked well. I was a bit paranoid about the gaps changing because the DPO had managed to get the drivers side gap 3/8" smaller than the door and the passengers side 1/2" larger than needed. so when I got them correct I wanted them to stay put.
I did remove the lifting frame at times when it got in the way.
David
Graham H
this is how I braced my 3A see that masking tape on that sharp corner? I still have dents in my head , even managed to bash it with the tape on.
Graham
DavidApp
I added a piece of shop towel to the corners. The towel helped to soak up the blood when I bashed my mead on the corners.
David
K TR4/4A Bracing the tub for fender and sill removal TR4? Triumph 6
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
Jim_Gruber Looking for Pics of behind Grille/Bracing,Crossmembers for an early '58 BE Bonnet Spridgets 20
Tr3aguy Body Bracing and Dolly Triumph 8
JPSmit New Year's Day Bracing Top Down Motoring Spridgets 7
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
T TR2/3/3A Body Tub Weight Triumph 8
F TR2/3/3A TR3A tub assembly Triumph 44
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
S TR2/3/3A steering column through the body tub Triumph 5
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
S TR2/3/3A tub work and holes Triumph 11
Popeye TR4/4A Best way to transport a bare tub? U-haul utility trailer? Triumph 11
S TR2/3/3A painting the body tub “inside” Triumph 31
S TR2/3/3A body tub welded Triumph 2
B TR4/4A Body tub differences - TR4/4A Triumph 8
C TR2/3/3A Flipping the tub Triumph 9
Hot Wings Title for a tub? Spridgets 9
CJD TR2/3/3A TR2 Tub Triumph 9
B T-Series MG TD Tub MG 5
B T-Series Tub Size MG 2
S engine is back, tub is bare,frame is bare Question Triumph 9
B Question about my 57 body tub Triumph 2
MGTF1250Dave T-Series TF Body Tub MG 3
MGTF1250Dave Nails for T Series Body Tub MG 8
S Body tub shims Triumph 1
J TR2/3/3A TR3 tub weight? Triumph 16
O TR6 TR 6 Body tub Removal Triumph 9
A Material between front fender and tub Triumph 15
G TR2/3/3A Threaded rod to Assist TR3 Tub Placement Triumph 6
PatGalvin TR2/3/3A Fitting tub on frame - 59 TR3A Triumph 8
M Tub Almost ready to come off [pics] Triumph 10
S TR2/3/3A tr3 tub shims Triumph 2
Twosheds TR2/3/3A TR3 Tub Hauling Question Triumph 16
PeterK TR2/3/3A Good TR3A tub for $400 Triumph 6
PatGalvin TR2/3/3A Tips for fitting tub on TR3 prepared frame Triumph 23
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
B Spotted a Bugeye tub- Spridgets 0
G Rust free tub in MN Spridgets 2
B TR6 I have to buy a used frame and tub for a TR6..... Triumph 14
MGTF1250Dave T-Series TF Body Tub Rebuild MG 10
S TR2/3/3A body tub tr3 Triumph 5
tinman58 The tub is on the frame! Triumph 11
John Moore Big Milestone! Tub is stripped Spridgets 6
apbos TR5/TR250 Triumph TR5 tub Triumph 1
S Midget body tub Spridgets 8
tony barnhill '63 Tub Epoxy Primed Spridgets 8
