Boot trunk seal alternative advice ?
bullittgt
I wasted half of the day trying to install a misfit boot seal I purchased from moss motors.Thankfully I followed forum advice and attempted to check the fit before I glued it in place.Its far too thick binding at the top and fitting it just on the bottom edge the trunk wont come close to being flush with the surround.Not the first time I have heard of mosses bad seals.I know....some have had success but not my car. After looking at some seal threads here my moss seal looks nothing like the seals I see here.
My seal is much narrower with a much steeper v grove which is symmetrical.no wonder it wont work
So ,does anyone have a recommendation of a seal that wont bind the hinges and also let the trunk close flush with the surround ?
There must be other vendors that stock a correct fitting seal.
Im not anal about originality at this point.just want it waterproof with a flush boot.
Possibly a bulb seal of some size?
Thanks guys
British_Recovery
Bronze
Since I didn't want to glue anything to the inside of the boot lid when it was rust-free, thinking the original seal acted like a sponge, I used an MGB boot lid seal and clipped it onto the aluminum edge of the shroud, with the joint at the bottom near the boot latch. I had to remove the rubber bulb section along the straight part of the lower edge so the lid could seat. No water entry in normal car washing, and the car is seldom in the rain.
Keoke
There must be other vendors that stock a correct fitting Boot seal.--Yep: Try Healey Surgeons.
Patrick67BJ8
Thanks guys
I purchased my seal from BCS...works great(no leaks with washings). Easier to install with the boot lid removed from the car and laid on it's back exposing the inside of the boot. Rough up any glossy surface and install only a little bit at a time using a good contact cement. There's an inside/outside lip so be sure to get that correct.
Brinkerhoff
I know you probably don't want to hear it but there is nothing wrong with Moss' boot lid seal, its shaped correctly and soft enough to seal with just the weight of the boot lid and a slight push to latch. Slamming a Healey bootlid will wreak havoc with the lid and the shroud over time . I've installed two on restored cars and achieved perfect fit and seal. The lip on the shroud is the culprit and can be tweeked easily before paint by bending it. Take a business card in one hand and while closing the lid slide the card between the seal and the flange. Pinching the card so tight it can't be pulled out means the flange is too far up. Start at the top edge.
Brinkerhoff
Cars 265.jpgfound a picture !
AUSMHLY
I found the seals from Moss and other vendors were a bit to hard to compress (for my boot lid). I found a bulb style that compressed a lot easier.
I purchased it from Pelland Enterprises Incorporated. www.Pellandent.com
Item code 19-3881
Description:
.80 x.50 EPDM flexible closed rubber seal; comes in Black. Sold with or without adhesive. Sold & priced by the foot.
I purchased 11 feet.
I am very happy with it.
Roger
AUSMHLY
Questions guys.
Been a while since I've posted. Non paying member this time.
Why can't I post a photo? (was going to post photos of the rubber trim)
This is what it says after I try:
IMG_3006.JPG: Exceeds your quota by 25.33 MB. <a href="misc.php?do=attachments" target="_blank">Click here to view your attachments</a>
GregW
Hi Roger,
Good to see you stop by now and again. I thought we talked about your photo issue a while back. When you were a silver member, you had uploaded more photos than a non-subscribing member is allowed. When your membership lapsed, you were over the limit from photos you had already uploaded.
AUSMHLY
Hey Greg, thanks for your kind words.
So, what do I do? Delet some of those photos, being I'm over my limit?
Anyone care to provide a simple, this is how you do it?
Being I don't visit her as often as I used to, don't really want to be a silver member if my wallet is to be involved.
I'm always happy to help my fellow Healey guys, and I have lots of photos. As the saying goes, a picture is worth a 1000 give or take, words.
M TR4/4A Trunk/Boot rubber seal. Triumph 8
T TR4/4A 4A Boot [Trunk] Seal Triumph 6
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
B Works Boot Rack [ For boot read trunk] Austin Healey 5
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
M TR4/4A Trunk/Boot lock key code?? Triumph 4
Y TR6 Triumph TR6 Trunk Boot lid wanted Triumph 4
brcree MGB Trunk lid..[boot] alignement MG 4
Jim_Newman Trunk/boot lid Austin Healey 9
R Boot or Trunk cover question Triumph 5
G I need a Vermillion trunk [boot] lid. Spridgets 3
pjsmetana Spitfire Anyone have a nice Spitfire Trunk / Boot picture? Triumph 2
MCNX_BFF Wedge Junk in my trunk--rust in TR7 boot Triumph 9
jjbunn Boot/Trunk Lock Mechanism Replacement Triumph 2
beaulieu Whats in the trunk/ boot of a XK 120 when new ? Jaguar 1
neilh boot[trunk] hinges - 79 midget Spridgets 9
WALTER Those darn trunk[boot] cavities Spridgets 9
mgbnew T-Series Trunk [Boot] latch. MG 8
D Your Must-have tools in the trunk [er...boot] Spridgets 32
J XK140 FHC trunk/boot Jaguar 1
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
S Boot Liner - BJ8 Austin Healey 19
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
