I was happily driving along about 15 mph (water temp: 190; oil: 80psi) when I heard an extremely loud BOOM! Without question the loudest noise I have ever heard produced by an automobile. The noise was followed by a metallic grinding noise that seemed to be emitting by the drive train. However, the engine died at the same time so I am not making any assumptions as to the cause. Suffice it to say, however, that something definitely broke and did so in a rather inauspicious fashion.
I pushed it home and put it up on jack stands (which, by the way, I'm getting very good at doing). Since I had taken a turn right before this event transpired I thought perhaps I had snapped an axle but they both look good. I then attempted to start the engine (in neutral and then in neutral with the clutch pushed in) and, while it will turn over, it will not start. I then drained the oil but evidenced no indication of metal pieces. I removed the valve cover and examined the plugs and everything looks fine. I then pulled the starter and am able to turn the flywheel. To the extent to which I could use a mirror to examine the flywheel, everything looked fine. I then drained the transmission oil (it has the Rivergate Datsun 210 conversion) and it, too, looks fine. However, I noticed that the propeller shaft will not turn. I can put the car in gear and spin the rear wheels easily enough (it has a recently rebuilt 3.9 differential with the Phantom Grip LSD) but the propeller shaft does not turn. Perhaps I snapped a timing belt and that is why the engine will turn over but not start but I'm guessing that the transmission suffered a catastrophic (or entertaining, depending on one's perspective) failure but would appreciate any thoughts.
Thanks,
Mike
Thanks,
Mike
