Desert Rat, I bet you could measure the width of your hinges at the point where they would probably bend, around the number 8 in my diagram. That's a whole lot easier than removing unless your car is apart. If it does have a bend might be able to fix with by squeezing with a C clamp without even removing the hinge at all. My car is in pieces and even then these hinges proved very tricky to install, needed a helper to hold the bonnet up and much jiggling to get the interior bolt in.
