Bonnet hinge gasket
BillyBud
I was wondering why my bonnet came so close to interfering with the body at the rear when closing. I didn't know there was supposed to be a spacer gasket where the hinge attaches to the bonnet. Can anyone tell me what this spacer gasket is made of and how thick it is? #4 in the diagram. Thanks.
Desert Rat
Mine does the same thing. When I tried adjusting the bonnet I found what could be the remains of that gasket. No idea what it was originally made from but mine was very thin, maybe paper or the same stuff as the pedal box seal but it crumbled apart when I took some out. What I found in mine wouldn’t act much as a spacer.
I think my problem is my bonnet may be warped more than I think it is and maybe the hinges. My mom backed into it with the Barracuda 40 years ago, the bonnet was repaired but I think the shop left a twist in it.
I need to take a hinge out and compare it to a new one and see.
tiiM5
I recall the material to be similar to black roofing paper installed on new roofs of homes.
I purchased some gasket material of similar thickness, a little thinner, from NAPA and traced and cut gaskets for my hinges. X-Acto knife was used to cut out the mounting holes.
TFR1
Original material was virtually identical to 30# roofing paper.(an asphalt impregnated paper) It is .060"thick.
Available from any roofing contractor. Probably for no cost.
B
BillyBud
I swear I has a roll of that stuff hanging around for years and just pitched it a couple of weeks ago. Isn't that always the way. Throw it away and you need it the next day after you do.
B
BillyBud
Desert Rat, I bet you could measure the width of your hinges at the point where they would probably bend, around the number 8 in my diagram. That's a whole lot easier than removing unless your car is apart. If it does have a bend might be able to fix with by squeezing with a C clamp without even removing the hinge at all. My car is in pieces and even then these hinges proved very tricky to install, needed a helper to hold the bonnet up and much jiggling to get the interior bolt in.
Stan Kowznofski
If you are not a purist at keeping everything original you should look into the later style 'scissor' type hinges. Much stronger and more adjustable plus they move the bonnet up and away so there is less chance of scraping paint.
B
BillyBud
Are the later hinges a bolt in replacement or do they require modification? I saw a set on Ebay for sale and the look like they have a different body side attachment.
Desert Rat
Never thought to try them on a Bugeye, seems like overkill with little benefit. I helped a friend add them to a 48 Chevy truck and swore I’d never do that again.
R bonnet hinge R or L Austin Healey 2
fmichaels Bonnet hinge holes Spridgets 4
W Bugey Bonnet Hinge Problem . . . Spridgets 5
GTP1960 TR2/3/3A Bonnet hinge issue/quality? Triumph 8
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
I Anyone have a bugeye bonnet hinge or bonnet stay they could sell me? Spridgets 5
Mychael Bonnet hinge. How do they attach at firewall. Spridgets 3
B bonnet hinge bolt removal Triumph 4
M Tilt Bonnet Hinge Kit 4 BugEye Spridgets 8
C BE bonnet tilt hinge help needed Spridgets 1
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
