tony barnhill
Great Pumpkin - R.I.P
Yep, JHack - in between working under race car, I'm trying to figure out why the '79 B doesn't have enough vacuum for the brake booster...tuned it up, set valves, went to start it & ignition was frozen & wouldn't free up...so I took it off, went out to the parts building, got another & installed it....did a compression check & found #4 is at 60psi - burned exhaust valve, I think...put everything together & went to move it out of way & broke the 2nd key off in ignition...pulled the thing up on trailer & parked it out front until I get a new ignition...
Got lots done on race car though!
