TR2/3/3A Block coolant passages plugged - pull the head?
If you have to remove the #4 liner get ready for about a half cup of small rock and sand-like material to drop on the #4 rod journal of the crankshaft.
Not just #4, but all of them! What i do is wrap a clean shop rag around each journal, and hold it with a twist of wire while you clean out the water jacket.
After the liners ate in place, turn the crank so the journal is at the bottom before you remove the rag n wire. That leaves the oil drilling facing down so nothing can fall into it, while you clean up the area with another rag n solvent.
Thanks all! Well, today was measurements and checking. The pushrods are still the 5/16", so I will replace those. The exhausts are still the larger stems. They look OK, so I decided t let my machinist make the call on replacement. I have given him quite a few jobs and he does stellar work. I will take the head up tomorrow and will be able to order the remainder of the parts once he does a look-see. I have started on the block and will do scraping/chiseling with vacuum clean-out, leaving the sleeves alone. Should be done by week's end, hope to put back together late next week.
Cheers, Dave
Scraping and vacuuming sounds much more prudent to me vs. power spraying. I approve and can stop cringing!
Yeah, the power washer is down and awaiting a new carb anyway! ;) For rinsing I will use a dingus I have used before - a length of 1/4" copper tubing with the end flattened to a nozzle. Hook it to a hose and you get a strong stream that gets the loose stuff without it being ginormous pressure like a power washer. Although it was fun using the power washer on my Buick straight 8!
Cheers, Dave
sp53: Dave you are probably going to do it anyway, but I thought I would mention to have your rocker shaft redone.
So when ordering parts I included a new rocker shaft, as well as the lock pins. Having worked on my Buick rocker, I assume it's about the same? Are the stanchions pressed onto the shaft? With the Buick you just heat them a bit to loosen. Is it the same on the TR?
Thanks, Dave
If the shaft is worn, then so are the bushings in the rockers and the rocker tips. IMO its better to send the whole thing off to Rocker Arm Specialists (or whatever they are called these days). They rebuilt.mine for about what the bushings and shaft would have cost me. Shaft and rockers appeared brand new, only the pedestals and end caps were clearly the originals. And the result has held up well for a long time now.
But yeah, the pedestals usually come off pretty easy, once you get the locating screw out. A little heat will help loosen them, but mine came off cold.
OK, today was Block Descunge Day. Got it all out. Turns out the muck was semisolid so was able to scrape and blast it out with air and house pressure hose.
Before:
You can see the muck behind #4 comes up to about 3/4" below the top of the block. All passages to cyl #3 blocked.
After:
You can see down to the bottom now. The water now flows completely around all the sleeves and out the block drain. Full open passages to the block front. Big change from before! Extracted about a pound of muck, both into the shop vac and all over the engine compartment! My assistant Ben said we just should've taken it thru a water park! Got it all cleaned up and will change the oil before firing. Now waiting for my machinist on the head.
Cheers, Dave
Cheers, Dave
Hello Dave
Good job on getting all the crud out of the block.
I presume that is a disc of some type I see sitting on the piston.
David
David - disc is washer used to keep the sleeves in place.
George - suggestions on cleaning method?
Cheers, Dave
Hello Dave
I was referring to the top of the piston in your before and after photos. There appears to be a raised portion almost piston diameter but off set to the center of the bore.
David
Oh I see. It's just discoloration of some sort, or a shadow from the flash. I will take another look this weekend.
Cheers, Dave
OK, I am in the process of reassembly. The head is on and torqued and I am finishing up on the rocker arm reassembly. I got a new shaft from Moss and it's OK, except for one thing. The holes for the Mills pin on one end seem to be drilled off center as neither one of my end caps fit properly. The other end is good. I know from other cars that this "offset" is sometimes used to ensure the proper part goes on but both end caps are the same in this case. Is this just sloppy workmanship or is something else afoot?
Also, I noticed that my old rocker shaft had just the end caps held on with the Mills pins to maintain oil pressure. The new rocker has threaded inserts in the end to seal it up good.
Pics coming!
Cheers, Dave
The caps are the same front & rear, so sounds like your shaft is made wrong.
Having the caps should certainly improve oil flow through the rockers (especially the front ones); but don't expect much pressure. The rocker shaft runs at essentially zero pressure; the holes on top of the rockers are open to the bore through the shaft through the gap between the bushings and there isn't a lot of flow.
Thanks Randall! Well I got it assembled and on. Had to use Cotter pins rather than the Mills pins but the threaded plugs in the shaft end are the primary oil "stoppers" anyhow. Rocker arm on, new larger pushrods and valves have been adjusted.
Next question: am getting ready to reinstall the manifold assy. Do I just use the gaskets dry as is or is any sealant recommended? Or does it need to move on heat expansion and need some copper antiseize?
Cheers, Dave
I put them on dry.
Dry it is. I got the manifolds back on and hooked up to the new exhaust. Also cinched down all exhaust system clamps. Put the carbs back on, did prelim adjust, and did turnover test, all good. Then did a quick compression test, 155 lbs all 4 cylinders. Also changed the oil. Then it started right up. Still have to do final carb adjusts/sync but it sounds pretty good.
2 questions:
1. The Book says adjust valves cold to 0.012" exhaust, 0.010" intake. I actually did all to 0.012". Should I go back and reset the intakes to 0.010"? Or are these clearances even correct?
2. What do you all generally set idle speed to? About 700 rpm?
Cheers, Dave
I forget the crossover point, but your car is late enough that you should have the aluminum rocker pedestals. With the aluminum pedestals, the clearance was revised to .010"/.010" Check the TR3 supplement in the back of the workshop manual, I think the change is documented there.
That said, I wouldn't pull the cover again for just .002" too large. You'll get more valve noise, but it won't hurt anything.
The dash tach is almost never perfectly accurate at low rpm; plus it depends a lot on other factors (like oversize liners). So I go for whatever rpm will let it idle smoothly and reliably. With my current engine (which is relatively stock except for 86mm liners), that's about 850 indicated. But I've owned other engines that didn't like to idle below 1500 (Ok, it wasn't exactly stock :smile: )
Like what Randall said, heck Dave if you can get a good strong idle at 700 things are good. At 12 it might make some more noise, but again I would drive it a few hundred miles to let stuff settle in, then re-adjust, good job!!
steve
