TR3driver
Great Pumpkin - R.I.P
Nope, those are all the standard holders and the harness is still the original 1956 item. Bulbs are slightly uprated, 2357 incandescents available at any auto parts store.mgedit said:Randall, I assume that the fix involves replacing the bulb holders and bulbs and rewiring to convert to signal/brake on the outside and brake only in the middle. Any advice as how to tackle this, which seems definitely worthwhile. Looks very good in the picture. Are those standard bulbs? Cheers, Mike
I don't have a diagram to share at the moment, but what I did was to mount a pair of relays to a bracket under the dash. One side of the coil for each relay goes to the turn signal circuit for that side of the car; the other side of both coils goes to the brake light circuit. So each relay will only activate if either the brake light is on and the turn signal for that side is dark, or if the brake light is off and the turn signal for that side is on. I also had to add some power resistors to provide enough load for the turn signal flasher to work properly.
One relay contact gets fused power (I added a new fuse block near the original one), the other powers the corner bulb on that side.
Everything connects into the original harness near the LH horn.
As it happens, I wound up adding a mechanically operated brake light switch as well, because the original hydraulic one wasn't reliable. But that is not required for the conversion. My original installation had another wire that ran over to pick up the brake light circuit at the switch on the RH side, which worked fine until the switch started flaking out.
Your car is negative earth and I was wondering if Geo was able to get the product to operate correctly in his positive earth TR3A.
