Just did a service on the car today. I checked the steering box for oil and couldnt see anything. Filled it up with around 0.1 gal of oil, quite alot. Shortly after i discovered why, oil leaks from the cables that goes to the steering wheel. I started to clean the area and was a bit surprised to see its not from the olive seal/ brassnut it comes, but from within the tube along the cables. Is the tube cracked or what could be the error?
I used EP90 oil.
I used EP90 oil.
Hi Guest!
