Johnski
I have a similar problem to the topic posted for "62BT7 Speedometer Problems". My speedometer will reach the right speed if I keep a steady speed 55+ for a while but doesn't go back down at slower speeds. Can this be caused by the cable?
I read about checking for the washer at the right angle drive end. Is there also a washer or O ring at the speedometer end? Based on the previous replys, sounds like I should fix sooner than later.
Hi Guest!
