Then you should only use oil manufactured in the 60s; IIRC Reid has some stashed away somewhere![]()
Yes, here's a glimpse of some of it, and note it's not for sale:
The shop manual says Castrol XL, so this wouldn't be concours correct.
Thank you Mr. BuzzkillThe shop manual says Castrol XL, so this wouldn't be concours correct.
I have never heard that. But then I admit I don’t know much.The W stands for Winter not Weight.
My OD stopped working, I filled it with 20/50 racing oil with Zinc. It started working again. It drops out of O/D sometimes by itself and yesterday on the way home from our Grand Strand British Car Club meeting in Myrtle Beach it stopped working again. Not sure why this happens.Here's an experiment to get more info. Note I haven't done this myself--at least not lately--so if anyone sees a flaw in my logic pipe up:
Get on a straight, traffic-free piece of road. Get into 4th/overdrive in the normal way at about 50-60MPH. Put in the clutch, put the gearbox in neutral, flip the O/D dash switch to 'Normal' (off) then rev the engine. This should isolate all the electricals from the O/D. Then put the gearbox back into fourth and let the clutch out gently (give it a little gas if necessary); if you're still in O/D as evidenced by engine RPM vs. speed the problem isn't in the electricals (it isn't likely, but not impossible that the solenoid is stuck in the on/up position). If you're still in O/D the problem is in the O/D itself: either the operating valve is stuck open or, as John suggested, the O/D cone clutch is embedded too far into the brake ring (that's all I can think of, anyway).
Have you tried fresh fluid? If the operating valve is sticking it might free it up. How many miles on your car? Has its fluid been changed regularly (20K miles or so for dino fluid; synthetic can go longer). I pulled my O/D at 205K miles and the cone clutch lining was still serviceable.
When the OD is working, if I flip the switch to normal, it kicks down immediately, gas pedal or not. How do I adjust the throttle switch? Thank you.A flakey dash switch can cause your symptoms; esp. if it occurs when accelerating. The throttle switch, assuming it's set correctly, will keep the O/D engaged after the dash switch is set to normal until the gas pedal is pushed a bit. Easy enough potential fix.
I don't think zinc has any benefit to the gearbox or O/D (but likely won't cause any problems). Gear oils use sulfur compounds for 'extreme pressure' additives (it's why they smell bad).
What oil were you using before the 20/50? If you were using SAE 30 engine oil, you may have low OD oil pressure, from a worn pump non-return valve or accumulator.My OD stopped working, I filled it with 20/50 racing oil with Zinc. It started working again. It drops out of O/D sometimes by itself and yesterday on the way home from our Grand Strand British Car Club meeting in Myrtle Beach it stopped working again. Not sure why this happens.
I don't know what oil was in the OD previously, I only bought it in May '22. I'm just happy when it works.What oil were you using before the 20/50? If you were using SAE 30 engine oil, you may have low OD oil pressure, from a worn pump non-return valve or accumulator.
I'll try it and report back soon, thank you.Bob's road test solution should work. Have you done so yet?
