• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
BJ8 Overdrive Stays Engaged
Editor_Reid
Platinum
Then you should only use oil manufactured in the 60s; IIRC Reid has some stashed away somewhere ;)
Yes, here's a glimpse of some of it, and note it's not for sale:
vette
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
S BJ8 Overdrive Issue Austin Healey 6
S BJ8 Overdrive issue Austin Healey 10
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
4tecdog BJ8 Overdrive oil leak Austin Healey 6
S Overdrive solenoid problem on a BJ8 Austin Healey 3
D Overdrive problem when raining - bj8 Austin Healey 23
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
davidb BJ8 Overdrive Austin Healey 16
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
AH67 BJ8 OverDrive Austin Healey 5
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
M overdrive bj8, smoked Austin Healey 1
D BJ8 Overdrive Switch on gear leaver top Austin Healey 2
R BJ8 overdrive intermittent Austin Healey 11
bighealeysource overdrive not disengaging right on my BJ8 Austin Healey 7
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
A BJ8 Overdrive Austin Healey 3
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 3
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
AUSMHLY BJ8 Mainshaft Needle Rollers, 32 or 33? Austin Healey 6
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 1
AUSMHLY BJ8 selector shafts and forks condition Austin Healey 2
LAW75 BJ8 Directional Indicators Austin Healey 4
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
W BJ8 Transmission Installation Austin Healey 0
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
Patrick67BJ8 Weatherstripping Seal & Caps for BJ8 Austin Healey 6
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 9
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
AUSMHLY BJ8 Laygear Wear Austin Healey 11
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S 1964 BJ8 Project Valuation Austin Healey 17
