BJ8 is running a bit rough. . .
ivyfalls
First post here, guys.
I have a 1965 BJ8. Recently I replaced a cracked distributor cap. Checked the wiring and everything seems to be fine. Each plug is getting spark as well. The problem I am having is that when I get the engine on the road up to about 2,000 RPM I get a bit of sputtering. I do not hear/feel the sputtering at idle. I checked the gaps of the plugs and they are within spec.
Any ideas? I know that is not a lot to go on.
...Recently I replaced a cracked distributor cap ...
With what brand (cap)? I've had similar problems with an aftermarket cap (think it was a Bosch). The best caps are good ol' Lucas (believe it or not). Also, if you're using suppression wires they can fire intermittently (stranded copper wire is best with stock-type caps).
Welcome to the Forum.
I
ivyfalls
I bought the Lucas cap from Moss. The wires are stranded. Just remembered that the wire cap came off cylinder #1's wire, but I tested it and there was good continuity after I reattached it. I may replace the wires anyway.
steveg
Some of the new caps have the wire-piercing screws drilled off-center in the hole in such a way as to not properly pierce the wire as well as hold it in place. I had one where the screw would sort of "nick" the end of the wire and pretty soon the wire would come undone.
Advanced Distributors sells a top-entry cap using normal push-in wires. This might be the way to go:
https://advanceddistributors.mybisi...op-entry-distributor-cap-with-copper-contacts
Patrick67BJ8
They also have the plug wires too and the correct rotors.
I've heard from a trustworthy source that some suppliers are buying empty Lucas boxes at flea markets and elsewhere and putting 'counterfeit' parts in them. I wonder if distributor caps are subject to this (last I checked, 'Lucas' caps were going for over $40, and a fake could probably be manufactured for just a few bucks)?
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
