BJ8 is running a bit rough. . .
ivyfalls
First post here, guys.
I have a 1965 BJ8. Recently I replaced a cracked distributor cap. Checked the wiring and everything seems to be fine. Each plug is getting spark as well. The problem I am having is that when I get the engine on the road up to about 2,000 RPM I get a bit of sputtering. I do not hear/feel the sputtering at idle. I checked the gaps of the plugs and they are within spec.
Any ideas? I know that is not a lot to go on.
...Recently I replaced a cracked distributor cap ...
With what brand (cap)? I've had similar problems with an aftermarket cap (think it was a Bosch). The best caps are good ol' Lucas (believe it or not). Also, if you're using suppression wires they can fire intermittently (stranded copper wire is best with stock-type caps).
Welcome to the Forum.
I
ivyfalls
I bought the Lucas cap from Moss. The wires are stranded. Just remembered that the wire cap came off cylinder #1's wire, but I tested it and there was good continuity after I reattached it. I may replace the wires anyway.
steveg
Some of the new caps have the wire-piercing screws drilled off-center in the hole in such a way as to not properly pierce the wire as well as hold it in place. I had one where the screw would sort of "nick" the end of the wire and pretty soon the wire would come undone.
Advanced Distributors sells a top-entry cap using normal push-in wires. This might be the way to go:
https://advanceddistributors.mybisi...op-entry-distributor-cap-with-copper-contacts
Patrick67BJ8
They also have the plug wires too and the correct rotors.
I've heard from a trustworthy source that some suppliers are buying empty Lucas boxes at flea markets and elsewhere and putting 'counterfeit' parts in them. I wonder if distributor caps are subject to this (last I checked, 'Lucas' caps were going for over $40, and a fake could probably be manufactured for just a few bucks)?
JamesD BJ8 Top Frame Bumpers Austin Healey 4
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
B Wanted BJ8 door hinges Austin Healey Classifieds 0
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
M 1966 BJ8 Top Austin Healey 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
T BJ8 Carpet Padding Austin Healey 4
S BJ8 Rear Seat Side Panels Austin Healey 3
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
66healey BJ8 shifter spring install Austin Healey 2
P BJ8 Frame Rust Options? Austin Healey 14
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
C My BJ8 Barn Find Austin Healey 15
J Nut size for BJ8 center console trim piece Austin Healey 8
