BJ8 FUEL TANK
BOBBYR
Hi Guys,
I found a local radiator shop that reconditions fuel tanks,so The fuel system on my 65 is just about done.From all the catalogs I look at,I have never seen a fuel filter or a fuel sock(located in the tank)in line to the fuel pump or the carbs. I would like to keep the stock setup but still would feel safer with some type of filter system.My question is ,is the strainer in the fuel pump the only protection in the fuel system or did I miss something?
As always,thanks for your help.
Bobby R
Dave Richards
I don't think you missed anything. Most folks add an in-line filter just before the carbs. I remember doing this in the early '70s. It was a standard, and prudent, modification.
Jerry
To add to the fuel filter. I got a clear (glass) unit that is about 6 inches prior to the carbs. This allows you to see if you are getting gas to the carbs when there is a starting problem.
Very useful! My fuel pump lost its pressure and the fuel filter told me that it was making noise but not pushing fuel!
Jerry
AUSMHLY
Hi Bobby,
I believe there is a brass filter screen in each carb too.
I too installed an inling fuel filter.
Mine is a by fram. It is plastic. (You can still see the fuel, if you want to, and more durable than glass).
I installed it about 5" after the fuel pump. Why there? It is out of sight, but easy to get to from under the car. Replacement takes about 10 minutes. Simply remove the two spring clips on each side, R&R with the new unit. When I ad improvements or safety items to my car, I try to keep them out of sight.
Happy motoring!
Roger
GregW
Platinum
Just to add further confusion, I installed my filter between the tank and pump. You need to add a ground to the fuel sender unit if you use rubber hoses to do this. I have stainless braided line and an aluminum filter. I put the ground wire in anyway.
GregW
Platinum
Hi Bob,
I’ve no personal experience with this, but I’ve heard tales of problems reconditioning tanks. There is a screen on the pickup tube inside original tanks. When the sealer is sloshed around to coat the tank, it can clog up the screen. One fix I’ve heard of is using compressed air to blow out the sealer, before it dries.
I use a clear plastic filter before the carbs (about $7.00 but harder to find than the tranlucent ones). Advantage of clear is you can see anything in the fuel before it filtered. it will settle to the bottom. I replaced the clips Roger spoke of with clamps 'cause I don't trust anything that pulls apart over the exhaust. His is under the car so no problem there.
When the car wouldn't start last week, I could see the fuel being pumped which eliminated many posibilities of the cause.
BOBBYR
BOBBYR
Hi Guys,
Thank you all for your help although I'm sure which way I'm going to go with this.I just hate to cut that fuel line.Anyway,I appreciate all the tips.
Bobby R
S BJ8 Fuel Gauge -Shows 1/4 tank when empty Austin Healey 10
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
N BJ8 out of fuel at 1/4 full tank Austin Healey 4
L BJ8 FUEL TANK SPOTTED Austin Healey 2
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
S BJ8 Fuel Pump Austin Healey 13
B Fuel pipe runs BJ8 Austin Healey 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
Bob_Spidell BJ8 Fuel Pump Trivia Austin Healey 0
M BJ8 Fuel pump Austin Healey 13
J BJ8 PhI ; #25805; Fuel Pump Austin Healey 20
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Ed_K Correct SU Fuel pump for a BJ8 [ PSI specs] ? Austin Healey 9
AUSMHLY Float bowl fuel height BJ8 Austin Healey 4
G BJ8 Fuel Gauge Core Austin Healey 9
Frank C. BJ8 Fuel Gauge Austin Healey 5
F BJ8 Fuel Filter Installation Austin Healey 14
G BJ8 Fuel gauge help Austin Healey 8
D BJ8 fuel consumption Austin Healey 5
J I need a picture of installed fuel pump for BJ8. Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
