BJ8 FUEL TANK
BOBBYR
Hi Guys,
I found a local radiator shop that reconditions fuel tanks,so The fuel system on my 65 is just about done.From all the catalogs I look at,I have never seen a fuel filter or a fuel sock(located in the tank)in line to the fuel pump or the carbs. I would like to keep the stock setup but still would feel safer with some type of filter system.My question is ,is the strainer in the fuel pump the only protection in the fuel system or did I miss something?
As always,thanks for your help.
Bobby R
Dave Richards
I don't think you missed anything. Most folks add an in-line filter just before the carbs. I remember doing this in the early '70s. It was a standard, and prudent, modification.
Jerry
To add to the fuel filter. I got a clear (glass) unit that is about 6 inches prior to the carbs. This allows you to see if you are getting gas to the carbs when there is a starting problem.
Very useful! My fuel pump lost its pressure and the fuel filter told me that it was making noise but not pushing fuel!
Jerry
AUSMHLY
Bronze
Hi Bobby,
I believe there is a brass filter screen in each carb too.
I too installed an inling fuel filter.
Mine is a by fram. It is plastic. (You can still see the fuel, if you want to, and more durable than glass).
I installed it about 5" after the fuel pump. Why there? It is out of sight, but easy to get to from under the car. Replacement takes about 10 minutes. Simply remove the two spring clips on each side, R&R with the new unit. When I ad improvements or safety items to my car, I try to keep them out of sight.
Happy motoring!
Roger
GregW
Platinum
Just to add further confusion, I installed my filter between the tank and pump. You need to add a ground to the fuel sender unit if you use rubber hoses to do this. I have stainless braided line and an aluminum filter. I put the ground wire in anyway.
GregW
Platinum
Hi Bob,
I’ve no personal experience with this, but I’ve heard tales of problems reconditioning tanks. There is a screen on the pickup tube inside original tanks. When the sealer is sloshed around to coat the tank, it can clog up the screen. One fix I’ve heard of is using compressed air to blow out the sealer, before it dries.
I use a clear plastic filter before the carbs (about $7.00 but harder to find than the tranlucent ones). Advantage of clear is you can see anything in the fuel before it filtered. it will settle to the bottom. I replaced the clips Roger spoke of with clamps 'cause I don't trust anything that pulls apart over the exhaust. His is under the car so no problem there.
When the car wouldn't start last week, I could see the fuel being pumped which eliminated many posibilities of the cause.
BOBBYR
BOBBYR
Hi Guys,
Thank you all for your help although I'm sure which way I'm going to go with this.I just hate to cut that fuel line.Anyway,I appreciate all the tips.
Bobby R
S BJ8 Fuel Gauge -Shows 1/4 tank when empty Austin Healey 10
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
N BJ8 out of fuel at 1/4 full tank Austin Healey 4
L BJ8 FUEL TANK SPOTTED Austin Healey 2
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
S BJ8 Fuel Pump Austin Healey 13
B Fuel pipe runs BJ8 Austin Healey 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
Bob_Spidell BJ8 Fuel Pump Trivia Austin Healey 0
M BJ8 Fuel pump Austin Healey 13
J BJ8 PhI ; #25805; Fuel Pump Austin Healey 20
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Ed_K Correct SU Fuel pump for a BJ8 [ PSI specs] ? Austin Healey 9
AUSMHLY Float bowl fuel height BJ8 Austin Healey 4
G BJ8 Fuel Gauge Core Austin Healey 9
Frank C. BJ8 Fuel Gauge Austin Healey 5
F BJ8 Fuel Filter Installation Austin Healey 14
G BJ8 Fuel gauge help Austin Healey 8
D BJ8 fuel consumption Austin Healey 5
J I need a picture of installed fuel pump for BJ8. Austin Healey 4
JamesD BJ8 Top Frame Bumpers Austin Healey 5
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
