I'm at a roadblock on getting the door latches adjusted correctly on my 66 BJ8, and I think I've found the problem. The slotted catch that cams over the striker has some play. It appears to be enough to allow the door to move in and out even after fully closed. I don't have the door panels or door seals in yet, so this may take up the slop, but I'd like to know now before it's all buttoned up.
If the play is really the problem, is there a cure? It appears that the slotted catch is attached to a round shaft with a rectangular part milled into it, and a corresponding rectangular hole in the catch. One of the two is either worn, or there is built in play. A new latch assembly is a bit pricey, if even available. I could weld the two pieces together, or drill and tap an overlaping set screw.
Any ideas?
Any ideas?
