BJ8 Door hinges
bluegrass john
I noticed the Drivers side door on my BJ8 seems to have a slight up and down movement when one pushes up or down on the door. Door closes better when lifting up slightly on the door. I was thinking of having the door hinges rebuilt, but do not want to cause any misalignment of the door fit by the rebuilding. The right side door has no play and operates very well. Anyone have this done and are there any suggestions who can do this sort of work? Suggestions appreciated !!
Thanks,
John
Keoke
Hi
.Sounds like the hinge pin is worn.
Replacing that may correct the error???
Alternatively, you might replace the whole hinge with new/good used.
Healey Nut
And if you do take the door off put masking tape around the edge of the hinge on the door pillar to mark where it is to save a lot of farting around when you put it back .also toss those crappy Phillips head screws and go buy some set screws with Allen key socket cap heads .....you will thank me for this suggestion once you try to remove those Phillips head screws .:eagerness:
Healey Nut
Patrick67BJ8
My Jule frame came back to me with the allen head screws and it's definitely an improvement. I also used all-thread screws for the motor mounts and it was a piece of cake to line up the motor mounts to the frame mounts.
Healey Nut
it's not the age, its the rust. Even allen heads suck to remove when they have been rusted in place.
Yes but you can a whole lot more torque with a Allen key socket than some old pozidrive screwdriver , especially when your the sixth guy that's had a go at them with the wrong tools .
BoyRacer
That's why every toolbox should have an impact driver and an assortment of bits. It makes getting out those hinge screws sooo easy. And when putting them all back in .... I use a cordless drill with about 7" or 8" of a big philips screw driver that I cut the handle off of.
Healey Nut
I have one in my arsenal of tools but only use in desperation and if I am not concerned about damaging anything else .
Going at it with a BFH is not my idea of fun , I prefer to use a little more care and finesse .
Top Down Resto
If you have a little time, use 50/50 mix of ATF and acetone as a penetrant (the best) let it soak for a few days. use a sharp pic and clean the paint from around the pozi screws ( paint will act as a glue, you need all the help you can get freeing the screws) I use a Snap On pozi drive screwdriver and a large cresent (adjustable) wrench or my pozi drive bit in a socket and 3/8 drive handle should do it without damage to the screws. Main thing here is brute strength without having the bit come out of the screw. Replacement pozi screws are different FYI (very slightly larger head ) and sometimes will protrude from the hinge. Try to save the originals if they are perfect . The screws only protrude out the tapping plates a little bit, once you get it turning they will usually come free
Carroll Phillips
Top Down Restorations
B
bluegrass john
Thanks to everyone for your suggestions; I discussed the actual rebuilding of the door hinges with an individual located in VA who specializes in hood and door hinge rebuilding for the muscle car restoration people; It turns out he has done Healey hinges and has been successful in removing the pins and boring out the pin hole and installing bronze oilite bushings. The next step is machining a pin from hardened steel to replace the original.............Sounds impressive. This fall I will be removing the door and sending him my left front door hinges to rebuild ! I will follow up with the results when this project is completed,
Thanks,
John
Thanks,
John
I'm probably not the only one on this Forum who would appreciate contact info for this individual (assuming he wants more business).
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
LAW75 BJ8 Door Locks Austin Healey 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
wangdango BJ8 door hinge milling? Austin Healey 2
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
T BJ8 door glass replacement Austin Healey 4
B BJ8 door seal attachement point. Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
M Bj8 door disassembly Austin Healey 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
Editor_Reid BJ8 Door Glass Austin Healey 6
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
tahoe healey BJ8 door trim Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
