I've just replaced the links on my dampers. The links each have one tappered bolt connection and one parallel bolt connection. When I removed them I found that the parallel bolt had a thin bush like washer fitted to it. The hole in the chassis plate is a little bigger than the bolt diameter. So to make the bolt fit a machined bush/washer was fitted. The bush matched the diameter of the bolt but had a raised collar/shoulder machined onto one face to match the diameter and the thickness of larger chassis plate hole. The whole thing was no thicker than two washers and allowed the undersized bolt to fit snuggly into the larger hole on the chassis plate without the bush part protruding through to the other side of the chassis plate preventing it from being tightened up. The other link didn't have this washer and the hole is slightly too large for the bolt.
I'm wondering whether anyone else has come across this "fix", and as I don't have access to a lathe I'm wondering if anyone knows whether you can buy such a washer.
Thanks
AJ
Thanks
AJ
