BJ8 Convertible Top repair
sjgcpa
The zipper to the rear window of my convertible top broke. It appears the only way to fix it is to sew a new zipper into the top. Has anyone ever done this with any luck? In addition, I know installation of a new top is a job, but what about reinstalling an existing top? The current top is in great shape (other than the zipper) and it is about 13 years old. How hard should it be reinstalling the top? Seems like it should be easy since it is already stretched and fitted. However, past experience tells me nothing is easy.
Thanks
Steve
Should be well within the capability of an auto upholstery shop. I had this done on my 1st BJ8 when I bought it and drove with it for 4 years before I stupidly sold the car in 1980. They could sew in new rear window plastic at the same time if yours is aging (while your up). Won't be electrically fused but should be quite serviceable.
I would prefer to do it myself. I am afraid the labor times the rate will eat me alive. I am told the installation of a new top is 7 hours. Seems it should come off easy and go back on easy since it has been previously installed.
Biggest problem would be geting a home machine to handle the heaviness of the fabric and thread. Most are not really capable of doing a good job on stuff this heavy. This is probably in the 99th percentile of what the typical home machine is designed for. Also a problem if you've not done any sewing. Zippers are among the hardest things to sew. Might want to consider taking out and re-installing the top yourself and having the sewing done by someone that does that sort of thing all day, like an auto uphosterer or a sailmaker. A distant second best would be having access to that sort of machine. Most home machines will either bog done and have to have the end wheel turned by hand for much of the length, or they will be inconsistant on the tension on the thread and have the thread intersection not buried in the fabric, or they will vary in the stitch length and actual tightness of the stitch. This is not including the difficulty with having the stitching evenly located all along the length of where its applied.
More power to you.
If you are going to go ahead youself, get lots of scraps and practice ahead of time, then stitch things by hand in a contrasting thread in a lot of areas that you can see to remove later and then put the final stitching in with the machine.
