BJ8 Alternator - small belt in large pulley
Healey Nut
I think it will run too deep in the groove and not run smoothly , it may get jammed and fail .
vette
When I put the alternator on my BJ7 I didn't change any pulleys. I used a NAPA/GM Delco alternator which is exactly like the one on my old Vette. The pulley on the alternator is just like the Vette's as well. The mounting came from Allen Hendrics. Sorry I don't have any measurements available now.
Keoke
Working on an alternator setup for a friend and would like to avoid swapping out any pulleys.
Can a normal 3/8" belt be run in the BJ8 1/2" crank pulley?
YEP
JamesD BJ8 Top Frame Bumpers Austin Healey 6
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
B Wanted BJ8 door hinges Austin Healey Classifieds 0
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
M 1966 BJ8 Top Austin Healey 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
T BJ8 Carpet Padding Austin Healey 4
S BJ8 Rear Seat Side Panels Austin Healey 3
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
66healey BJ8 shifter spring install Austin Healey 2
P BJ8 Frame Rust Options? Austin Healey 14
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
C My BJ8 Barn Find Austin Healey 15
J Nut size for BJ8 center console trim piece Austin Healey 8
