The heat shield on the firewall, located directly behind the engine, is "screwed" directly to the firewall. The ones under the floor are also screwed inplace and are provided with additional thermal isolators in the form of "Square Blocks" as indicated by John earlier. No original heat shields are glued directly to structure.-Keoke
Yep they are Asbestos TH. Home Depot has a Bricker board that is being used as a Non-Asbestos replacement. Similarly, those purchased from the regular suppliers are not fabricated using an Asbestos material either-Keoke
