Bending Brake Pipe Without A Special Tool
jjbunn
I am assembling the parts needed to repair my front driver's side brake system, wheel bearings and sway bar. I sourced a replacement 16P used caliper, and bought the short length of steel brake line that goes between the caliper and the brake hose from Victoria British. I also have the pistons from the old caliper (extracted with compressed air), and a new seal kit, also from VB.
This brake line has fitments on each end, and is straight.
I need to bend it into a U shape, but know that if I'm not careful I will crush the pipe. Do I need a special tool, or can I improvise a tool? And what operational tips do you have for me?
Thanks!
vettedog72
Sounds like you need a tube bender. I don't know how you will bend a u with out the tube bender. They don't cost much, you may find one at WalMart or Big Lots. Good luck.
prb51
Julian,
A small pipe bending tool is inexpensive and a good investment. I tape the old pipe to the new at the connector and (using the tool) replicate the bends. Pretty easy.
I've done it by hand before too but you have to finesse the job and a bad bend is hard to fix properly and a built in weak spot.
roofman
They sell these in different sizes and you will need the smaller one.
R
RonMacPherson
One tip, I have found that if I pack sand into the pipe, before bending it helps lessen the possibility of a "kink" irregardless of tubing bender used..
Andrew Mace
I've yet to kink a brake pipe, and I've never used either a dedicated tool, nor have I filled the pipe with sand. The trick is simply to use whatever you might find lying about as a "mandrel" rather than bending it "freehand"! Tight bends can be done by forming the brake pipe around a steel or copper pipe, and bigger bends can be done around various sizes of glass bottles or pretty much anything solid and round.
PAUL161
Julian, There is also a spring wound tube bender. They come in various sizes and work great! Choose the proper size, slide the tubing into it and bend the whole spring. The spring slides off easily when done. No distortion to the tubing, And, their cheap! Of course, if your bending stainless, eat your Wheaties first or get a vise held bender.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]One tip, I have found that if I pack sand into the pipe, before bending it helps lessen the possibility of a "kink" irregardless of tubing bender used..[/QUOTE]
Ronnie, you're showing your age again.........
Twosheds
Note:
Remove sand before installing tube.
R
RonMacPherson
Hey, I'se older than dirt.....
Now, forgot to mention, gotta make sure the sand is not from Puerto Rico.... seems liek their sand has been "pedroized"... :crazyeyes:
jjbunn
jjbunn
Many thanks for all the advice. Looks like a trip to Harbor Freight is in order :smile:
Raymond Bending Brake Line MG 61
vping Bending brake lines. MG 18
HealeyDave General Tech Bending tabs on chrome gauge rings Triumph 5
longbridgehealey Bending bridge pipes Austin Healey 16
drooartz Bending exhaust pipe Spridgets 12
R Tube Bending Spridgets 11
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
