John_Mc
Well, after my unsuccessful rebuild of my slave cylinder, I bit the bullet and just bought a new one from BPNW. I went with the "OE" TRW model. On the box is a warning not to use silicone brake fluid, but it also includes the instructions to bench bleed the unit before installing. I have not heard anything like this before for a slave cylinder. I'm thinking this was intended for a master brake cylinder since on the side of the box is a label that has the part # PJL705P and shows a sketch of a brake master cylinder. It also says on that label ROVER Defender 90, so I'm thinking BPNW put a TRW slave cylinder in a box intended for a brake master cylinder out of convenience. No bench bleeding would be required for a slave cylinder, right?
