smaceng
Hi All,
I've got the 1275 in the BE and it is running OK, but it is still too hot. I had the stock downflow radiator cleaned out and the shop said the flow is good. I'm using the yellow 6-blade fan and a Mini Mania high flow water pump. My first big drive it ran right at 190-195, too hot for me on a 80s day. I then checked the 'stat and it opened right at 190. So I changed to one that opened at 175. Still running too hot. Then changed to water wetter with just a small amount of antifreeze, still too hot. So my next idea is to have the radiator recored with a high density core and 3 tubes deep. Anyone know of what core vendor and part # would work? Any one know of a shop in the San Francisco area that has done this job? I would like to keep the stock look as much as possible with the old top and bottom tanks. BTW, fan belt is tight and the dash gauge has been calibrated using another probe.
Too hot in CA
Too hot in CA
