EWD
Re: ‘74 TR6
Have a new battery and have a disconnect on the negative post. When the battery is disconnect, the charge holds. When it is connected, there is a charge loss to zero over a few days. Thought it might be one of the leads (direct to the battery) for a new Retro Radio (to keep memory, but the drain is very slight. Disconnected the lead to verify, and the battery still loss charge.
When you connect the battery, there is a loud click in the right front under the carbon canister, which I assume is the anti run on activating. Could this be the problem?
Thanks in advance for your help.
Will
Will
