I agree 100% the welding wire is also very flexible.Da bigga da betta ... that's a long run to the solenoid. IIRC, we used 00 welding wire for my BN2. Also, the connection to the terminals is critical; either solder or a proper crimp.
As with everything there is a debate as to which--batter cable or welding cable is "better". There are pro's and con's with each. FWIW I have always used battery cable on any boats or cars--including my race cars but that's just me. In any case be sure to use high-grade terminals either soldered or staked and well insulated, harnesses, clamps, etc. so you don't have any issues with chafing.I agree 100% the welding wire is also very flexible.
Great to hear welding the wire is recommended here. We'll just finish installing the suspension from 4Wheelonline onto the Jeep Wrangler and we'll start working on buddy's new BN6 project.Da bigga da betta ... that's a long run to the solenoid. IIRC, we used 00 welding wire for my BN2. Also, the connection to the terminals is critical; either solder or a proper crimp.
... Bob S. is a pretty smart guy and he must have his own reasons for using it. I think I am pretty smart too and I only use battery cable, even on my race cars where weight is an issue.
Invest some time and form your own opinion.
What's the load your solenoid pulls?:What's the load your solenoid pulls? You'll need to know that to properly size the cable. You can always overshoot, but why not do it right?
See if you can find a copy of SAE-J1127, good info in there about low voltage battery cables.
Solid copper is not a good choice for this application.
What about soldering up copper plumbing pipe and coating it with tool dip? Then it could double as the fuel line.
