Battery - BJ8
SimsBJ8
What battery should I put in my BJ8?
Group size 27? Group size 24?
Cold Cranking Amps?
Not looking for original, just something to drive the car on weekends.
Thanks in advance!
Patrick67BJ8
Duralast Gold 27 DLG(Autozone) fit perfectly for me.
WD 67 BJ8
the 27 works good. You need to know which one you need because of the differences between negative and positive ground connections.
FWIW, Group 24 is usually specified in the cross-reference books for 6-cyl Healeys. But, whatever fits and cranks your engine would be OK. Group 24s are getting hard to find; Costco, for instance, used to carry them but hasn't in a while.
BOBBYR
Hi Bob, If I were you , put in an Interstate battery . They are by far, the best battery you can get .
Bobby R
I had premature failure from two Interstates in my Mustang. The guy who rebuilt my starter and generator told me almost all 'common' battery brands--even Optima--are now made in Mexico and are caca (and his name's Martinez).
blueskies
Maybe I shouldn't admit this, but my BJ7 currently has a Kubota tractor battery. Except for the Kubota label, it looks as if it belongs. The original battery in the 1999 Kubota wouldn't turn over the diesel engine anymore, so I bought a new battery from the Kubota dealer. Then I discovered that the battery in the tractor was not the problem; a battery terminal clamp had broken, and after fixing that the 18 year old battery continues to work well in the tractor. So the Healey got the new battery. I'm hoping that it will last well, although Kubota may have changed its battery supplier in the meantime.
RAC68
Hi All,
A while back, I had purchased 2 Optima batteries (1 for my Acura and 1 for my Healey) and thought I had a failing Optima battery in my Acura and replaced it after 5 years. I had had it with Optima batteries when the Optima purchased for my Healey also started to fail shortly after and decided to call Optima and complain. Reaching an Optima technician, he explained that inactivity of the Healey allowed the battery to go down farther then could be easily recharged and to attach the battery, I believe but not sure, in parallel to a second standard battery to provide the necessary resistance needed for raise the charge sufficiently in the Optima battery. I followed his direction and I have been using my Optima battery in my Healey for the past 10 years.
If I had understood the Optima battery better, I probably would not have replaced it in my Acura.
Just a thought,
Ray(64BJ8P1)
D New Battery Needed for BJ8 Austin Healey 9
wangdango BJ8 inner battery hold down? Austin Healey 4
J BJ8 Battery Support Wood Block is it 3/4" or 3", ours is 3"? Austin Healey 5
H location battery divider BJ8 Austin Healey 6
D BJ8 Battery Austin Healey 1
JeffR Battery Size for BJ8 Austin Healey 2
Frank C. Battery for BJ8 Austin Healey 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
