Balancing Carbs...
After getting a pair of mufflers hanging on the Healey's headers, I could start doing some preliminary tuning on the Weber 45 DCOE carbs.
After removing the carbs and linkage a while back for cleaning, the air balance was the first order of business.
I ordered a couple of these Carbtune IIs from a place in England. Best device of the type I have ever used. Note that those are stainless steel rods and not Mercury.
I do have one issue that needs to be resolved, the #6 cylinder is intermittently backfiring on idle. That suggests a lean condition to me, perhaps there is still some obstruction in the low speed circuit...? As soon as you give it some throttle, it picks up evenly and the miss goes away.
What fun would it be without a little challenge?
attachment.php
Don't know anything about Webers, but very impressive setup to read air flow. your cars looking great Randy. Any chance you'll be heading down to Conclave Texas in June?
AHCA conclave is in San Antonio this year.
Randy, Love your pictures, really helps. Is your coil happier mounted to the side?
Did you do that because of heat or did you change your generator/mount?
Thanks, Shelly
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Blonde Healey Girl:
Thanks, Shelly
<hr></blockquote>
Thanks Shelly!
Still have the original generator, but I'm considering an alternator (lighter). I originally moved it to get away from both heat and vibration.
