TR2/3/3A Bad thinking?
tinman58
I have been driving the TR3 a lot the last couple of weeks. The machine work on the 250 is taking longer than antisapated, I love the TR3, but...... It has to be outside, it is covered under a "shed" but open to the weather at both ends. The car stays dry but there is surface rust starting to form. I hate to see it like this. The rust comes off but what am I not seeing? My thoughts are to sell the 3 until I can get a bigger 4 car garage. Here in California that's a million $$$ . Please talk some cents in to me. A little surface rust can't be all that bad! Any ideas on how to keep it dryer?
NutmegCT
Dan - describe the "surface rust". Do you mean on unfinished steel? Or do you mean on finished surfaces like paint, chrome, etc.?
A few photos might help.
Tom
tinman58
tinman58
Tom
Unfinished metal. Nuts bolts etc.... Not bad just sad.... The head bolts and nuts have some spotting. WD-40?
tinman58
tinman58
I will take some pictures tomorrow.
NutmegCT
Dan - on my TR3 and Mercedes-Benz, I prevented surface rust on bare metal just by rubbing lightly with motor oil on a soft cloth. Up in Canada many folks actually spray oil on the undercarriage for just that same purpose.
Tom
M_Pied_Lourd
Fluid Film.
Cheers
Tush
rnpennington
Tom
I have a TR4 that does that automatically, no matter the season, here in Texas.
rnpennington
Have found a good car cover will prevent a lot of that. I have a car a motorcycle in the driveway because the garage was converted.
tinman58
tinman58
I have I cover my motorcycle, dark mold started form on some area's. So the motorcycle is in the garage with the 250 and the Wife's audi. I also have a cover for the TR3 but I think the moisture is coming up from the concrete.
NutmegCT
Just another clue on "car covers". They often just trap the moisture that rises from the ground. And if the air becomes warmer overnight, the moisture in the air condenses on the cooler steel under the cover. Not good.
Tom
mgedit
I would also suggest parking on a sheet of plastic or a tarp to stop moisture from coming out of ground. All suggestions better than seling the 3. Cheers, Mike
sp53
I experienced the same problem. I had my driver tr3 out under a carport while I was working on a restoration, and the small little deals started to rust, fuel lines, head bolts, and anything tinnie. I like the idea of driving on a tarp, and I am going to try that one. Basically, I accepted the rust and figure even at the rate it is rusting it will outlive me. Plus I did not babysit the car as much when I took it somewhere. One thing I have done for the stuff that can be black or a kinda that dark metal look and still preserve the metal from rusting was to get a high quality Permanent Marker and color it right place. I gota say it works really well, but sounds really cheesy.
Geo Hahn
I see no one's agreeing to selling -- good.
X2 on using Fluid Film on those parts. It is clingy, creepy but harmless (like my prom date). I use it on unpainted bolts and other parts as even garaged in the desert those things will eventually start to corrode. In some of the country they have it at the tractor supply stores, I got it from Amazon.
My TRs have spent winter outdoors under quality car covers and survived just fine. And the car doesn't mind - so don't feel guilty.
CJD
LPS3 is made for just this problem. It dries to a waxy film that protects. It's what they use on aircraft, many of which sit in the weather for a 50 year lifespan.
GTP1960
Another rust inhibitor is offered by the evaporust folks.
it's called "rust bandit", and is a spray on, Water base, non-petroleum (easy cleanup) product.
would work well if car is under a tarp/cover & /or shed, but not for full outdoor exposure, as it would wash off.
i am very impressed with the orison evaporust products.
you can check it out: https://www.orisonmarketing.com/rustbandit.html
PeterK
You could treat the bare metal with phosphoric acid which will leave a nice protective coating as well as stop any rust that you can't see. Phospho metal prep, let sit, then wash off with water (yes water) and you'll have a whiteish coating that will last until you are ready.
Fluid Film is sold by John Deere dealers as well as tractor stores. It is a lanolin product that for me has never worked well and it leaves a mess to clean off. Good for shooting inside of the frame but hard to get it clean for paint prep. Boeshield T-9 is a great protectant for bare engine parts, etc. Originally made for aerospace, holds up well, and no gummy mess like FF.
But for bare body parts, Phospho treatment can't be beat IMO. Except maybe ---- etching primer?
croz
Hello Dan,
A couple of ideas ... How about weather sealing that "shed'. Tarps are cheap. You can probably get one that will cover the whole building.
Plus - lay a large tarp on the ground then drive onto it, cover the car with a decent quality outdoor car cover and then wrap the remainder of the tarp over the top of the car. The main thing is to keep the moisture out and still let the covered car breath. I used this technique, on a TR6, for a couple of winters. Worked well even under the snow!
Have you looked into the cost of an aluminum patio cover. You can probably get one that is large enough and free standing, with one side wall closed to the prevailing weather. Make it 7 ft tall, 10 ft wide (sloped) and 20 ft long. The car should tuck in there nicely. Wrap as mentioned above. Later it can be used as a covered BBQ area.
Cheers,
Steve
NutmegCT
Another idea: back in the Dark Ages, when I was but a lad - guys used Scott's Liquid Gold wood preservative on metal tools, to prevent surface rust.
I'm too cheap for that - so I just use a tiny bit of motor oil wiped on with a cloth.
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
I Effect of bad valves on engine performance? Triumph 9
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
