NutmegCT said:Dale - yesterday you started a thread on your high RPM idle speed. This morning, Paul asked how the situation is going. At 10:46am today you replied:
At 10:40 this morning you started another thread on your cable linkage.Tinster said:end of this thread-
dale
At 10:44 this morning you started *another* on manifold vacuum.
At 1:07 this afternoon you started *another* on your front wheel bearings.
At 2:32 you started another, on New Year's cooking.
Help! We can't all keep up with ya!
Dale - we might feel more like helping if you'd let folks help on one problem before just dropping it and veering off onto another problem. If guys are trying to help you, leaving them in a cloud of dust with "End of this thread" doesn't exactly encourage involvement.
T.
Andrew Mace said:Basically, Dale, once the front is up on stands:
1. remove wheel
2. unbolt caliper and hang somewhere so as not to stress the hose
3. prise off grease cap
4. remove cotter pin and castellated nut
5. remove hub/rotor assembly, trying your best NOT to drop the washers, bearings and other stuff
If either bearing looks bad, falls apart, has bluish spots anywhere from overheating or is otherwise damaged, then time for a new one.
But before you do ANY of the above, as Don implies, how do you know a bearing is bad? Could it just need (re)adjusting, which only involves #1, #3 and half of #4 above?
Brosky said:Rich,
Dale is an expert on how to install those bearings and races. He took his bearings and races out last year to clean and repack. Did a nice job and wrote a great tutorial on it too!
DrEntropy said:...and p'raps how to do it properly.
Always good to learn "how to fish".
