TR2/3/3A Bad Day in the Garage
Geo Hahn
I had to replace the TR3A starter - the rubber drive thing was slipping. I bench tested the spare that I'd had on the shelf for years and it spun fine.
The install went well, I used a length of wire to hold to the top rear nut in place - that was great, was able to fully tighten it with that set-up:
Unfortunately, it seems that when I tightened down the brass nut holding the cable to the starter it created a dead short inside the starter body. Worse luck, when I tried to start it the short caused the contacts inside the solenoid to weld up and even though I immediately released the solenoid it stayed 'on'.
I always keep the battery ground post loose during such maneuvers but a lot happened in the time it took to grab it and pull it off:
That's the battery-solenoid cable. No other damage other than some melting of the battery case where that cable fell against it.
That & the fact that I am typing all this with one hand while the other hand holds a bag of ice.
Gliderman8
Sorry to hear. I guess it could have been a lot worse. Maybe consider a battery cutoff switch at the terminal.
TR3driver
Great Pumpkin - R.I.P
No problem, a little electrical tape and it will be good as new!
:devilgrin:
Too bad about your hand, though. Those things are a lot harder to replace than battery cables!
RJS
OK so I was once working on my starter solenoid up on the fire wall near the battery. The outer case of my brand new watch my wife just gave me for Christmas must have touched the pos. terminal on the battery and at the same time shorted against the metal battery hold down. Huge sparks wherein I proceeded to melt a giant chunk into the side of my new watch! HOLLY S__T! My wife is going to positively kill me.
I actually hid it from her and called the manufacturer with a sob story. The customer service rep was very kind suggesting I should box it up and mail it back as defective. Sure enough, they sent me a brand new one! Wow! Disaster narrowly averted. And, you now better believe I have terminal covers on the battery just like these: https://www.remybattery.com/Snap-On-Terminal-Protectors-P547.aspx
HerronScott
Oh no! That is a bad day.
I don't suppose you have a spare starter for the spare?
Scott
TR4nut
Whew. Glad just an icepack is involved Geo. You have convinced me that I'm keeping the battery cutoff I have on my 3A!
sail
Bummer. Heel quick I'm not sure if that bag of ice should be allowed for your 100 degree drive.
Geo Hahn
Geo Hahn
Follow-up: The hand is fine, all I got was a small blister on my index finger -- I've had worse blisters from using a screwdriver aggressively.
The big rear post had broken through the insulator that protects it from the starter body -- replaced that and all is well.
TRTEL
Was the nylon? insulator that passes through the alloy end plate? or the next one which is some sort of plasticized woven material that broke? Having just rebuilt one I was concerned about the second one.
RC64
I know the feeling well! Very same thing happened to me when we attempted the first start after the body was back on. I cinched down on the nut a little to much too. The results was the crushed fiber insulator (photo) and the grounded post. There were plenty of observers on hand, so fortunately, the fellow tasked with activating the solenoid switch recognized the problem quick enough so that the contact didn't weld itself closed. Even with it shorted for a few seconds, the cable got hot enough to melt the shrink wrap on the lugs and a bit of the insulation. In addition to a new cable, I followed their unanimous advise to take this as an opportunity to upgrade to a gear reduction starter to replace the original. The new setup works great.
Rick...
Tinkerman
Bummer George. Glad the damage to your hand was light and the fix was easy. Just anothrr day in the shop eh.
Dick
toysrrus
As the olde saying goes:
"A BAD DAY IN THE SHOP IS BETTER THAN A GOOD DAY AT WORK"!!!!!!!
Keep on Motoring.
Russ
Geo Hahn
Geo Hahn
Was the nylon? insulator that passes through the alloy end plate? or the next one which is some sort of plasticized woven material that broke?...
The nylon tube was fine (don't think much can happen to it) it was the washer pictured by Rick.
In retrospect, there is probably no need for that first nut to be more than snug - though it then helps to have a wrench on it when you tighten the nut that holds the cable.
Yep, first nut, its job is to provide stop for the cable and help hold it tight. Doesn't need any pressure on or against the starter. I learned the hard way years ago. I twisted one off.
Marv
CJD
Where are the faulty grounds when you need them? Glad the injuries were minor on both sides!
jfarris
George,
Glad you are OK and the damage was fairly light.
I have a battery cutoff switch to add to my TR3 which is still positive ground. Do I add the cutoff switch (the one with the green knob) to the ground side?
Thanks to all,
Geo Hahn
Geo Hahn
Yes, I think it is best to cut-off the ground side. I have one that has been on the shelf -- maybe it will get called into use now.
Newkie Not a bad car to have in the garage MG 7
S Bad day in the garage Spridgets 25
kyreb1862 Bad Day In The Garage Part 3 MG 0
kyreb1862 Bad Day In The Garage Part 2 MG 3
kyreb1862 Bad Day In The Garage MG 6
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
