Ok, I have been neglecting the Spitfire (78) for too long and the wife is starting to bug me to get it running or take it to the salvage yard! So, I have the engine out and have installed new rings. I had the motor rebuilt several years ago and ever since it was leaking oil out the rear end. I tried changing the rear seal twice to no avail, which led me to investigating other potential causes. Someone on here suggested I might be getting too much crack case pressure, which prompted me to pull the engine again and pull it all apart and check everything! What I found was, the people who rebuilt the motor before did not get the ring gaps right. In fact, the gaps were more than double what the book says is max. This made me think that maybe the excess gap was causing excess blow-by into the crank, which in turn could be the cause of my incessant oil leak (which usually only occurs when I shut the motor off). Anyway I have new rings that are properly gapped so I'm hopeful that will resolve the oil leak.
Now, the car currently had DUAL Weber 40 side drafts and a slightly hotter street cam. However, I think the dual Webers are too much carb for this little car for street use, so I want to drop it down to a single Weber 40 DCOE.
<span style="font-weight: bold">Question:</span> Where is a good source for a manifold that will work for this application? Also, does anyone have a Spitfire with a single Weber side draft?
