Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
8 sided, 56mm socket. It's not available in a regular US store. 6 and 12 sided ones don't work. AHSpares sells one, or you might have luck borrowing one from a Healey friend like I did. Also Left side one is reverse threaded!
rich
Also recently an original factory Churchill tool sold and I noticed it has a bar through the middle which locates in the axle housing to take the side load from tightening it. that means the nut only gets the rotational force and there is no chance of it slipping off.
Moss or British Car Specialists sells the stamped socket . The MGA takes a smaller one than the Healey both are octagonal. I've used mine with an impact and they've held up ok. Randy's would last longer obviously. Only if you were doing this job daily would the Churchill tool be necessary as its way overbuilt. The nuts are a little pricey , try not to ruin them when you remove them. Kevin
