Awakening the Beastie...trying to!
The good news is that there is/was life. That bit of encouragement should help give you incentive to keep going.
Coils don't often go bad. The problem is likely to be elsewhere. I'd repeat your test with a spark plug (and a single wire) connected directly to the center post of the coil... bypassing the distributor cap, rotor, and plug wires completely. That should help you pin down where you are loosing the spark.
Anyway, give that some thought and congratulations on getting that spark even if it only lasted for a second or two. It's all very encouraging.
Don't forget that it takes more than just 12v to the coil to get something out. It actually only produces a spark at the instant where the 12v (or ground on the other side) is interrupted.
My next step would be to double-check your splice. As a soldering newbie, you may have had a "cold" joint or something that opened up from the vibration, or something like that.
Or it could be that there is another problem, and that's why the DPO cut the wires.
