I replaced all mine for "just in case" cause the blocks oldand to get a more thorough block cleaning. Not hard to do and I think I got them from AH Spares.Getting my engine block ready for assembly and was wondering about replacing the small brass plugs in the water jacket. I believe there are seven of the near the top of the block. Is this a concern or should I leave well enough alone?
Thanks in advance,
Jim
There's a casting plug on the rear of the 'log' intake manifolds, and a carb backfire can blow them out (ask me how I know). I managed to get it back in, and put some JB Weld around the edges to help keep it there.
JB Weld is wonderful for many things!
When I last overhauled my BJ8's engine--many years ago--the machinist put an epoxy around the edges of all the newly-installed casting plugs. He builds engines for racers, and I figure he knows a thing or two (he also used brass plugs).
... fit a new oil pump too, they wear out.
Even if the pump was producing good pressure at tear-down?
Granted, I don't run the RPMs you do__or for sustained periods__but I've been doing okay with the rotor-type pumps for coming up on forty (<39) years.Randy,
I see you have a 100-6 oil pump there. I hope you do not have that pump in your engine. Are you aware that there was a BIG reason that Austin changed from the rotor style to the gear style oil pumps.
Richard
Well, sign me up as the fortunate recipient of dumb luck; both my own car, as well as Jim/Leonard's Longbridge 100/6 have BJ8 cams (mine was used as a blank for the Isky T3 grind) and therefore required the use of the later drive spindle (the BJ8 cam has a smaller drive gear, necessitating the use of a spindle with a matching larger diameter gear).BMC strengthened the pump drive shaft when they switched to a gear type, which means that it's fine to use a vane type as long as you have the stronger shaft. Previously it could bust on a cold day.
Overall efficiency is about the same, but vane pumps pump more at low rpm and they last a lot longer than the geared BMC effort. They're not recommended for racing engines where revs are constantly above 5000.
Check out SC Parts (Germany) or Dennis Welch for verification.
