TRnorwegian
Perhaps Pedro has been doing some maintenance on my car too?
TRnorwegian said:Any good suggestions to how I blow the moisture out of the carbs?
emmett1010 said:Anders: That car has
You should have NEVER let Dale touch it!
Emmett
Andrew Mace said:...or, if you haven't already, just get rid of whatever fuel is still in the tank and start over with fresh fuel!
poolboy said:If this is the model Weber that you have you can remove the Cover (part #1) and expose the float chamber. You should be able to clean it out pretty good by doing that.
https://webernorthamerica.com/pdffiles/32_36DGV.pdf
poolboy said:You at least need to identify them. One of these ?
https://www.webernorthamerica.com/weber_carburetor_schematics.html
