I've attached a couple pictures of the axles from my solid-axle TR4A. A couple questions:
1. The pictures show rust patches on the axles, the lower one being the worse of the two. Can I just sand this off, or will that leave me with a weak area that might eventually lead to cracking and breaking?
2. I've measured the hub runout as 4 mils on one axle and 10 on the other. This was measured at the outer edge. 4 mils might be OK, but 10 strikes me as too much. I can't find a spec for this in the shop manual. Does anyone know the spec, or lacking that, I'll take opinions?
3. The rear axle had only a few ounces of oil in it, so I'm a bit worried about the differential bearings. Is there any easy way to check these short of taking it all apart? I can't feel any looseness, but that doesn't always mean something.
Thanks for any ideas, either hard info or just opinions.
