Anyone interested in some swapping?
Got a lot of cats Kim?
As I remember an 1/8 inch hole punch is just right.
regularman said:
Why did you ask?
Four containers of kitty litter in the pic.
I have the stock air cans for a twin SU set up.
Original "Italian Job" on DVD, unopenned.
Free to good home.
Baz said:
regularman said:
Why did you ask?
Free to good home.
One of the Mini guys (Cliff??) would probably love the original "Italian Job" . Fun entertainment and a BUNCH of Minis getting thrashed!!
Baz said:
regularman said:
Why did you ask?
Free to good home.
What size SUs are the air filters for? I may be interested.
Stuff I have:
2A629 948cc Cylinder head NOS, never had valve guides installed, spent 30 years in the PO’s garage.
2A629 head, used, probably worthless except as a doorstop
8G712 948cc Camshaft NOS, still has shipping wax on it, in original oil paper and box.
Crankshaft, possibly for 948, but not sure what part number, surface rust but may be of some value
Sump
4 x AH Chrome hub caps one is a little rusty
1 Bugeye Ignition switch, worn, needs looking at, but has new H-S-OFF knob
3 additional new H-S-OFF knobs
2 Bugeye Speedometers, clean but condition unknown
2 Bugeye Rev-counters, mechanical type, clean but condition unknown
1 Mechanical rev-counter cable
1 Bugeye Oil/Water combination gauge, clean but condition unknown
1275 Exhaust manifold, one bolt broken off in flange hole ;-(
3 Starter motors condition unknown
1 Dynamo with mechanical rev-counter drive and reduction gearbox, but gearbox pinion is stripped
1 pair H1 carbs complete on manifold with heat shield, shield is a little bent, otherwise quite clean
1 pair H1 carbs and manifold and heat shield, scruffy, disassembled but mostly complete
1 pair H1 carbs parts only, dashpots and other parts missing, very scruffy
1 pair front lever shocks, used, condition unknown
2 original Bugeye steering wheels one is chipped but clean serviceable, the other is very badly worn
Bugeye LHD dash
3 pairs Bugeye windshield pillars, one pair is chrome-plated but not very well done
2 x Bugeye windscreen frames
Bugeye windscreen, glass unbroken + frame
3 x left hand door handles (short arm) for MkII Sprite/MkI Midget but fit Bugeye
Ok back to the swap idea......I have said for years the problem with e-bay is I don't know what you want me to sell. I have parts form all kids of cars (1986 Toyota Supras, 1986 NIssan 300 ZX, 1990 Supra, 1980 NIssan 280zx then there's the midget stuff...steering wheel, horn hub, radiator from???? cracked windshields (2), weber carb cover and all sorts of misc stuff that I have picked up) I don't sell it cause it seems like I might need it, but if someone else had a use for it....I would love to see it go to the right person. I figure pay for shipping...its yours.
i REALLY need a front clip!
the big chuck between the fenders! ;(
also a front blinker lens and a
rear sidemarker......zimmmy
Thought I already posted this, but I don't see it so if it is a repeat, sorry!
Chris I am interested in the BE windshield glass and frame. Is it the early type (hood studs across the top) or the later BE type with a stud at each corner? If you are interested in a swap, either let me know your needs or I can make a list (a daunting task) of the stuff I have!
PS I need the two-stud type.
Zimmy,
I have a rear side marker. Yours for the cost of postage.
I'm fresh out of front lenses, but I do have the chrome retaining ring if you need it.
Anyone have a bugeye horn? You know the Beep beep one.
I have a horn, but I do not know if it is the beep beep one. How can I tell?
Hook it up, has a single contact and is grounded through the body. Is kind of small and has a flat peice of strap to mount it.
Don't know what else to say. Would be intrested for sure Trevor.
The one I have looks more like the windtone horns only slightly different.
Zimmy,
A "front clip" is fenders, hood, grill, etc.
I have the part that goes between the fenders in the front, a bit crusty but servicable (especially with some Slick Sand). I have a front blinker lens. I have several side markers.
Is this what you seek?
Think there is a pic in the Moss cat, Page 67, item 61.
I do have a later model one so is not critical at all. Thanks.
jack, I think I may have a horn, will look when I get back from work...
Zimmy, that grille arrived today, so I will have that and the surround to get to you.
I need to do some fancy plier work with the new grille first, make sure it fits in the mouth, then it should be good.
